Random CELs right after shifting...
Old Jun 14, 2004 | 10:45 PM
Eluzion's Avatar
Default Random CELs right after shifting...
It's completely random and has happened about 4-5 times already. It only happens when I'm WOT and shifting near redline, but right when I shift the car throws a CEL and has no pedal response. The rpms just begin slowly dropping and if I try to step on the gas, nothing happens or it barely responds. The only way to fix the problem is to flip the key real quick (turn the car off and on) and everything is fine.
I never had a chance to check the CEL since I'm usually in the middle of the road. I'm about to take the car to the track and I would really hate for this to happen on the track. Any ideas what it might be?
I'm running a built B16A with a Drag3 kit. Boosting about 13psi. Running Uberdata.
Thanks.
Old Jun 15, 2004 | 11:34 PM
Eluzion's Avatar
Default Re: Random CELs right after shifting... (Eluzion)
Bump
Old Jun 15, 2004 | 11:38 PM
Freemantle's Avatar
Are you running a check valve? That sounds like a MAP problem.
Old Jun 15, 2004 | 11:43 PM
swlabhot's Avatar
Default Re: Random CELs right after shifting... (Freemantle)
He said hes running Uberdata so no check valves.
When you get the CEL, just pull over and jump the service connector to check the code. Its no point wasting time and effort trying to guess what the issue is when the CEL will help in indicating where the fault is.
Old Jun 16, 2004 | 09:33 PM
Eluzion's Avatar
Default Re: Random CELs right after shifting... (swlabhot)
Well it happened again today. I pulled over to a gas station and checked it. Was code 16.
I think the car went into a limp mode as well. Redline when that CEL came on was at 3500.
*shrug* no idea what it could be... injectors are all plugged up properly (rc 550's).
Old Jun 17, 2004 | 08:17 AM
Eluzion's Avatar
Bump.
Old Jun 17, 2004 | 09:32 AM
tegmech's Avatar
are you running ftl by any chance?
Old Jun 17, 2004 | 09:45 AM
tthame1's Avatar
Default Re: (tegmech)
Did you have to install injector clips? If so, one of the connections may be loose.
Old Jun 17, 2004 | 12:37 PM
Eluzion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegmech &raquo;</TD></TR><TR><TD CLASS="quote">are you running ftl by any chance?</TD></TR></TABLE>
Nah, not running FTL.
Old Jun 17, 2004 | 12:40 PM
Eluzion's Avatar
Default Re: (tthame1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthame1 &raquo;</TD></TR><TR><TD CLASS="quote">Did you have to install injector clips? If so, one of the connections may be loose.</TD></TR></TABLE>
Do you mean the metal clips? If so, yeah (don't you need them regardless?). All the injector connections seem to be fine. I tried wiggling and slightly tugging them when the car is idling and they all seem fine.
I'm wondering if it's something to do with my B&M FPR or fuel pump (Walbro or BBK).
Old Jun 17, 2004 | 12:53 PM
swlabhot's Avatar
Default Re: (Eluzion)
The ecu is complaining about your injectors
Old Jun 17, 2004 | 02:45 PM
tthame1's Avatar
What kind of connections did you use? If you used butt splices, that may be your problem.
Old Jun 17, 2004 | 09:20 PM
Eluzion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthame1 &raquo;</TD></TR><TR><TD CLASS="quote">What kind of connections did you use? If you used butt splices, that may be your problem.</TD></TR></TABLE>
I'm not quite sure what you mean? I am running a OBD1 GSR harness. The wiring harness and injectors plugged right up.
Old Jun 17, 2004 | 09:21 PM
Eluzion's Avatar
Default Re: (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">The ecu is complaining about your injectors</TD></TR></TABLE>
I wonder if it's something to do with Uberdata. I don't know of anyone else having the problem though, and they're running UD as well. *shrug*
Old Jun 18, 2004 | 08:52 AM
darylfiend11's Avatar
Im having the same problem. I get on it and after i let off the cel comes on throwing a code 43 fuel system failure. I have lucas 440 injectors with the safc. Im stumpped too. Also when i drive and go to about 4000rpm and then let the engine slow itself down right when it gets to 2000rpm the cel comes on throwing the car into limp mode giving me a code 43.
Old Jun 18, 2004 | 09:44 AM
powerofdreams8's Avatar
Default Re: (darylfiend11)
Check your thermostat ground.
Old Jun 18, 2004 | 10:27 AM
Vtec92Civic's Avatar
Default Re: (powerofdreams8)
for that code 43 . . . I use to get that a lot. Actually took my car into a shop because I couldn't figure out some other issues with my car after messing with it for a couple weeks. I have not had a code 43 for months, but they said the car tossed a code 43 for them and they found that my stock FPR was stuck closed so my motor was getting way to much fuel, so they replaced it.
Try checking your FPR
91ef_civic
Mar 22, 2011 02:33 PM
jdm-turtle
Jul 22, 2010 12:53 PM
MumBleZ_94gsR
Jul 10, 2010 06:12 AM
lilpastrana
Feb 27, 2007 04:59 PM
See Are X
Jul 13, 2003 09:26 PM
