MSD window switch...can you use it with zex?
Old Jun 12, 2004 | 01:20 AM
hondaeg8's Avatar
Default MSD window switch...can you use it with zex?
i have a zex kit and i'm debating on getting the rpm window switch. can i use it with a zex kit? i just don't want to over rev while spraying.
will there be any problems hooking up the msd window switch with a zex kit since zex activates itself by the tps sensor at WOT?
Old Oct 9, 2005 | 03:04 PM
animal chin's Avatar
Default Re: MSD window switch...can you use it with zex? (hondaeg8)
Old Oct 10, 2005 | 04:24 AM
JSPECSIR's Avatar
Default Re: MSD window switch...can you use it with zex? (animal chin)
yes you can. you have to put a relay on the output wire of the window switch. and then you feed your power from you arm switch through the relay to the zex box. then the box only recieves power when the window switch lets it.
Old Oct 13, 2005 | 04:19 PM
Default Re: MSD window switch...can you use it with zex? (5THGENSI)
TheRappist
May 8, 2009 07:56 PM
jnasty
Jan 30, 2007 06:28 PM
zcivic91
Jan 15, 2003 12:03 AM
teggygsr
May 5, 2002 07:46 AM
