Motor Rebuild time!
Old Jun 13, 2004 | 08:52 AM
boostdGS's Avatar
Default Motor Rebuild time!
Well, the orifice in my AEM FPR blew out, sendding ALOT of fuel into my motor, injectors, through my vacuum lines.. wastegate, bov, chargepipes, EVERYTHING.
Long story short, my motor hydrolocked from too much fuel, bent rod. :x
I'm going to rebuild it, but with just a block guard, no sleeves.
What piston/rod setup would you guys recomend? And, which brand blockguard?
Old Jun 14, 2004 | 07:36 PM
boostdGS's Avatar
Default Re: Motor Rebuild time! (boostdGS)
Old Jun 14, 2004 | 07:39 PM
Rod.'s Avatar
man that sux. That is not a thing that happens often.
Not sure on blockguard. You can go with cp pistons and eagle rods.
Old Jun 14, 2004 | 08:12 PM
J337_UNIT's Avatar
wow ive personally never heard of this happening.. crazy!
im a fan of crower rods (eagle second choice) and CP pistons.. thats the set up im gonna go with when i rebuild this winter...9.2:1 compression ratio.
Old Jun 14, 2004 | 08:15 PM
Muckman's Avatar
Moderator in Chief
CP Pistons with Pauter rods.
Old Jun 14, 2004 | 08:26 PM
Jockobo's Avatar
Default Re: Motor Rebuild time! (Muckman)
were u driving when it happened ?
Old Jun 14, 2004 | 08:35 PM
patdemps's Avatar
Default Re: Motor Rebuild time! (Jockobo)
cp pistons and eagle rods...
thats what im doing after this summer/spring.
what compression do you want to run?
Old Jun 14, 2004 | 10:55 PM
Spoolin18's Avatar
CP pistons, JE pistons...either...i had JE's and were very happy with them..however i hear that CP is very good as well. By far Eagle rods...they are the best bang for your buck..and if you want to go crazy and spend a good amount of money then go with Pauter or Manley
Old Jun 15, 2004 | 02:32 PM
boostdGS's Avatar
I had just put the motor under alot of load, and it was running rough( i guess that the regulator had blown by then)
I turned off the ignition, and parked. I came back 20 minutes later, took a while to start, was flooded, started up, sputtered, and then stalled. Compression tests today came back 40 40 60 50
Old Jun 15, 2004 | 06:45 PM
illicon2003
Guest
Posts: n/a
look into golden eagle sleeves ?? maybe some wiseco pistons, or arias. I've heard good things about that stuff.
Old Jun 16, 2004 | 04:24 AM
boostdGS's Avatar
I've decided to scrap the entire car. Parting out everything soon
kpjo4
Mar 11, 2010 07:56 PM
guy_from_nerk
Feb 16, 2009 05:29 PM
Topdawgg
Dec 23, 2006 06:17 PM
PnkRokCountryboy
17
Nov 20, 2005 04:08 PM
89civichatchback
Nov 20, 2004 07:04 PM
