fuel pump on turbo ls
Old Jun 15, 2004 | 05:32 PM
2SlowDC's Avatar
Default fuel pump on turbo ls
would it be alright to run a stock fuel pump on a boosted ls @ 7psi.
im running a vortech fmu and a b&m fuel optimizer w/ 370cc rc injectors tuned on afc
Old Jun 15, 2004 | 06:59 PM
Sohc Driver's Avatar
Default Re: fuel pump on turbo ls (lsVtec...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsVtec... &raquo;</TD></TR><TR><TD CLASS="quote">would it be alright to run a stock fuel pump on a boosted ls @ 7psi.
im running a vortech fmu and a b&m fuel optimizer w/ 370cc rc injectors tuned on afc</TD></TR></TABLE>
No..stock fuel pump will not suffice. You will need to run ontop of your stock fuel pump, a high pressure inline fuel pump.
Khoi
Old Jun 15, 2004 | 07:08 PM
J337_UNIT's Avatar
you shoud get a 8:1 FMU disc for that... and you should also get an inline pump to support the higher pressure needed
Old Jun 15, 2004 | 09:54 PM
2SlowDC's Avatar
im tuning the car tomorrow. so I wont be getting enough fuel? how much does an inline fuel pump cost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">
you shoud get a 8:1 FMU disc for that... </TD></TR></TABLE>
whats wrong with the vortech fmu?
Old Jun 15, 2004 | 10:53 PM
2SlowDC's Avatar
Default Re: (lsVtec...)
Old Jun 16, 2004 | 04:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsVtec... &raquo;</TD></TR><TR><TD CLASS="quote">im tuning the car tomorrow. so I wont be getting enough fuel? how much does an inline fuel pump cost?
whats wrong with the vortech fmu?</TD></TR></TABLE>
Nothign is wrong with the vortech FMU...he just noticed that you are running 370cc injectors..if that is the case..then you need to be sure you have an 8:1 ratio disc for your vortech FMU. If you have say a 12:1 ratio disc that comes with the drag or revhard kits..your gonna be running way to rich.
Khoi
Old Jun 16, 2004 | 04:28 PM
b16ahybrid's Avatar
Whats the fmu ratio?
I would highly recomend a intank fuel pump, As long as your not running a 12:1 fmu you should be fine with a reg. 255lph. I would try a 4:1 fmu to start with, if you need more fuel maybe go up to a 6:1.
I ran a 4:1 w/310cc injectors and was still too rich, I used a sfc to LEAN it out a little more. max fuel pressure was 85psi.
Old Jun 16, 2004 | 04:35 PM
b18b98's Avatar
To be safe, just throw in a 6:1 disc for the FMU and a warlboro high pressure fuel pump. Definetly dyno that thing afterwards.
Old Jun 16, 2004 | 05:06 PM
2SlowDC's Avatar
how do i know what disc i have?
Old Jun 16, 2004 | 05:40 PM
b18b98's Avatar
if its as big as the cover, its the 12:1 disc. A little bit smaller its the 10:1 and so on and so forth.
Old Jun 16, 2004 | 06:18 PM
2SlowDC's Avatar
i think i have the 12:1 disc. its about the size of half a compact disk
Old Jun 16, 2004 | 07:16 PM
This is how you tell the difference...
Measure your disc:
12:1 ----&gt;2.71"
10:1 ----&gt;2.46"
8:1 -----&gt;2.22"
6:1 -----&gt;1.85"
If you are in fact running a 12:1 ratio....then running with those 370cc injectors will make you run **** rich. You can either keep the 12:1 ratio and run stock injectors..or keep the 370cc injectors and just swap out the disc with an 8:1 ratio.
I suggest you getting a highpressure "inline" fuel pump for an FMU setup. If you do a search, there are several threads as to why a high pressure "intank" fuel pump will not suffice for an FMU setup.
Khoi
Old Jun 16, 2004 | 08:43 PM
b16ahybrid's Avatar
Default Re: (Sohc Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver &raquo;</TD></TR><TR><TD CLASS="quote">
Khoi</TD></TR></TABLE>
I dissagree completely. I ran a 12:1 fmu and 255lph INTANK pump for a while with no problems, thats not to say everybody can do the same, but it's been done safely.. Now if your running larger then stock injectors, there is NO reason a 255lph INTANK pump won't work, unless your trying to run 15psi (on a fmu it's plain stuipid).....I still run that pump, but I ditched the fmu for hondata.
Old Jun 16, 2004 | 09:10 PM
Default Re: (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">
I dissagree completely. I ran a 12:1 fmu and 255lph INTANK pump for a while with no problems, thats not to say everybody can do the same, but it's been done safely.. Now if your running larger then stock injectors, there is NO reason a 255lph INTANK pump won't work, unless your trying to run 15psi (on a fmu it's plain stuipid).....I still run that pump, but I ditched the fmu for hondata.</TD></TR></TABLE>
If it were up to me..I would ditch the FMU all together and run either uberdata or hondata...but as far as the FMU setup goes..I am just going by other experiences here on honda-tech with people running high pressure intank fuel pumps with their FMU setups. Just look for it and see. BTW..did you ever dyno your car with the FMU setup?
Khoi
Old Jun 16, 2004 | 09:41 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver &raquo;</TD></TR><TR><TD CLASS="quote">If it were up to me..I would ditch the FMU all together and run either uberdata or hondata...</TD></TR></TABLE>
That I agree with.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver &raquo;</TD></TR><TR><TD CLASS="quote"> BTW..did you ever dyno your car with the FMU setup?
Yep 226whp @9psi of boost.
Old Jun 16, 2004 | 09:49 PM
That I agree with.
Yep 226whp @9psi of boost.</TD></TR></TABLE>
Do you have a graph of it with your A/F graph? I was just curious as to what it looks like.
Khoi
Old Jun 16, 2004 | 10:14 PM
b16ahybrid's Avatar
No I don't, but I do have a readout (nuber wise) of the afr in rpm's. In 100 rpm increments. I'd have to dig it out but recalling from memory My air/fuel ratio was between 11.9:1 and 12.2:1 once in boost up to 8,200rpm.
It's not you typical line graph, but it's the same thing if you plotted it out.
Old Jun 16, 2004 | 10:15 PM
b16ahybrid's Avatar
it's a lot better looking (number wise) then my afr ratio now.
Rubixcu7
Jul 1, 2005 05:43 AM
vietjdmboi
Jan 24, 2004 11:48 PM
untitled
Jan 7, 2004 03:29 AM
stockgreencivic
Nov 3, 2003 07:44 AM
ridnmyhonda
Jan 29, 2003 09:35 PM
