question on afc settings?
Old Jun 14, 2004 | 04:40 AM
darylfiend11's Avatar
Default question on afc settings?
i have a 93 prelude with a t3t3 .60ar housing and a 50 trim, no intercooler,440 cc lucas injectors, tial wg
2.25in dp to stock exhaust. it is only running four lbs but about what should the settings be on the afc? becuase the problem is is it gets in a little bit of boost then it throws a map sensor seeing to much volt code. it mainly happens as i let off throttle after getting on it. so if anyone could help that would be great.
i know a missing link should hlep but the only thing is i shouldnt need one.
thanks
Old Jun 14, 2004 | 07:09 AM
Default Re: question on afc settings? (darylfiend11)
how about if i wired a 3v zener diode ?, or i read somebody else had a similar problem and it was there o2 sensor? what do you guys think?
Old Jun 14, 2004 | 07:22 AM
Mag00n's Avatar
What settings are you using? Heres what I use.....
http://www.thedropshop.tv/vafc.htm
Old Jun 14, 2004 | 08:03 AM
Default Re: question on afc settings? (SICKSOLVTEC-T)
oh fo sho! thanks man i read all of that i will try it out.
Old Jun 14, 2004 | 08:45 AM
Mag00n's Avatar
np Hope it fixes the problem. It sounds to me like you just didnt have enough correction...
Old Jun 14, 2004 | 09:21 AM
yeah it fixed it for the most part. But the cel comes on after i let up on the throttle, but not as often.
Blue94Accord
May 14, 2010 06:46 PM
nicktagz
Sep 25, 2006 10:49 AM
wshondaman
Dec 19, 2004 06:36 PM
Haberdasher
Jun 11, 2004 04:44 PM
squirrel
Aug 26, 2003 09:39 AM
