boosted-hybrid, tuned you guys must read!
well i whent and got my fresh motor tuned by jeff on friday, and i was very impressed by his shop and skill. He took his time and did it right and thats what i like it wasnt like 1 hour worth of tuning for 300.00 which i dont see how a car could be tuned that quick. Jeff spent almost 6 hours on my car until the map was perfect, so if your in need of tuning and in the tri state area go see him! you will not be disappointed
Modified by B18C1CYA at 7:23 PM 6/12/2004
Re: boosted-hybrid, tuned you guys must read! (B18C1CYA)
What were the results? I have seen more than a couple of Jeff's tunes. He always does good work from what I can see.
Re: boosted-hybrid, tuned you guys must read! (0x64)
Set-up: GSR block, 9:1 pistons, rods, Bensons sleeves, built head, stock GSR IM, 880cc precision injectors, walboro 255lph fuel pump, Hondata, GM 3bar, Drag kit, Tial WG upgrade, Greddy Profec spec II, 2.5" dp, 3" exhaust.
Here are the graphs:
tuning at 10.5psi
tuning at 13.5psi
tuning at 10.5psi
tuning at 13.5psi
Re: boosted-hybrid, tuned you guys must read! (boosted hybrid)
nice to see that new dyno getting worked. Jeff you figure out that spec 2 any better from playing with his? Im going to the track a few times in the neext few weeks and wanna get down some hi boost runs. Hit me up IM
Re: boosted-hybrid, tuned you guys must read! (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">nice to see that new dyno getting worked. Jeff you figure out that spec 2 any better from playing with his? Im going to the track a few times in the neext few weeks and wanna get down some hi boost runs. Hit me up IM</TD></TR></TABLE>
I'm sure Jeff will IM you later today. As far as the spec 2, I think that there just weren't any issues with his. It was cooperating very nicely for them. Good luck with yours...
Re: (turbozxi)
we where using 93 octane and here are some dyno pics and some of my setup[IMG] the only problem is my breather setup sucks getting to much oil in my catch can to jeff
Re: (turbozxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi »</TD></TR><TR><TD CLASS="quote">I like the 3 fan setup for the dyno. </TD></TR></TABLE>
Re: (94goldjungsr)
What's the turbo specs?? Looks like a very smooth powerband. Im very impressed with the tuning he did on my buddies GSR. Car drives like its stock and just pulls and pulls.
the son and the heir
Re: (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote"> the turbo specs are t3/t4oe .63 stage3 exhauste and .54 or .57 on the cold side, the power is very smooth and just pulls hard </TD></TR></TABLE>
Congratulations on the tuned GSR. Jeff, once again, good job and way to put the new dyno to good use.
Re: (Pfieffdog)
catchcan setup looks ok. I would just put a return line from the can back into the block somewhere.
Is there a breather on the valve cover, it looks pluged in the pic?
