SVE 3 bar MAP sensor?
Old Jun 15, 2004 | 03:53 PM
SSS2000's Avatar
Default SVE 3 bar MAP sensor?
$62 for the 3 bar MAP sensor and connector. This seemed like a pretty good deal, does SVE make quality products?
Here is a link to the stuff.
http://www.lightningmotorsports.com/sveharness.htm
Thanks!
Old Jun 15, 2004 | 05:36 PM
86si's Avatar
Default Re: SVE 3 bar MAP sensor? (MilanoRedLST)
Spend another $40 and get one from GM,you can find those connectors in the junkyard for next to nothing
Old Jun 15, 2004 | 07:08 PM
SSS2000's Avatar
Default Re: SVE 3 bar MAP sensor? (86si)
What is wrong with this one? It looks the same as the GM.
Old Jun 15, 2004 | 08:05 PM
rioninja's Avatar
I would bet my car that that is a GM sensor.
Old Jun 15, 2004 | 09:10 PM
Jared's Avatar
haha, the one in the box still has the gm sticker and part number on it
Old Jun 15, 2004 | 11:43 PM
Eluzion's Avatar
Bump.
Anyone recommend this map sensor? I know Camp1320 sells them for a pretty good price (the GM ones) but not sure if it comes with everything you need like this one does.
Old Jun 16, 2004 | 06:11 AM
SSS2000's Avatar
Default Re: SVE 3 bar MAP sensor? (Eluzion)
I ordered one, I'll let you guys know how it works out.
Old Jun 16, 2004 | 08:38 AM
Eluzion's Avatar
Nice. They look good and seem to be a pretty resonable price.
Old Jun 16, 2004 | 08:51 AM
RyanEJ8's Avatar
Sounds like a good price, I might get one too.
Old Jun 16, 2004 | 08:52 AM
tthame1's Avatar
I bought one of those a few weeks ago and it is great. It came with everything needed to install it, except the wire itself. It also included very detailed instructions. Unlike some of the other sensors I've tried, the plug was acutally the correct one for the sensor.
Old Jun 16, 2004 | 09:36 AM
SSS2000's Avatar
Default Re: SVE 3 bar MAP sensor? (tthame1)
Good to hear, thanks!
Old Jun 16, 2004 | 10:06 AM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoRedLST &raquo;</TD></TR><TR><TD CLASS="quote">$62 for the 3 bar MAP sensor and connector.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si &raquo;</TD></TR><TR><TD CLASS="quote">Spend another $40 and get one from GM </TD></TR></TABLE>
As already noted, the SVE unit is a GM one, in the GM box, with their sticker over the GM sticker.
BTW, $62 + $40 almost buys two GM 3 bar shipped to the door from http://www.gmpartsdirect.com. I feel bad for anyone who spends $100+ for a sensor
Old Jun 16, 2004 | 10:22 AM
tthame1's Avatar
Default Re: SVE 3 bar MAP sensor? (J. Davis)
That may be the case, but I would gladly spend the extra few dollars to ensure that I've got everything I need, including really good instructions and not have to go hunt around in junk yards, then try to figure out how I'm supposed to hook the thing up.
Old Jun 16, 2004 | 10:34 AM
It's three wires; power, ground, and signal return. Hondata has an excellent writeup to be found here: http://www.hondata.com/3barinstall.html
You can order the MAP sensor pigtail from GM, too, for less than $9. Junkyard ones work fine, there are 2-3 of those style connectors on any given GM, but they are not "splined" or "keyed" correctly as only the GM 3 bar connector has the correct splines. Thirty seconds with some side cutters and the problem is solved.
Now, SVE seems to have a price on the OEM part that is within a few dollars of what GMpartsdirect charges. If you go through them, cool beans. It was the poor guy paying over $100 for an OEM GM 3 bar that made me sad.
Doodasi
Nov 1, 2017 02:54 PM
young geezer
Aug 1, 2009 12:44 PM
fafsa
Dec 1, 2004 02:06 PM
CaptainMorgan
Jan 27, 2004 04:45 PM
qwklude82
Jan 8, 2003 09:43 PM
