Dyno Tune and then exhaust system
If I were to tune my car with a 2.25in exhaust system and then upgrade to a 3in. exhaust system, would that cause a big enough change in airflow to necessitate another dyno tune?
Re: Dyno Tune and then exhaust system (95GSRTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT »</TD></TR><TR><TD CLASS="quote">my tuner says it shouldnt need to be retuned, since boost is boost. Your not making more boost, just more hp. </TD></TR></TABLE>
lol your 'tuner' is wrong.
on higher whp cars, changing the exhaust can have dramatic effects on AFR and will need to be retuned....
on lower whp cars, a afr of .2-.3:1 change can easily be expected
Re: Dyno Tune and then exhaust system (Mase)
what would happen if you tuned open downpipe, and then bolted up a 3" exhaust?
Would it run richer?
I'm pretty sure that if tuned with an exhaust, and if you ran open you would run a bit lean right???
Re: Dyno Tune and then exhaust system (TurboChrgd_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic »</TD></TR><TR><TD CLASS="quote">what would happen if you tuned open downpipe, and then bolted up a 3" exhaust?
I'm pretty sure that if tuned with an exhaust, and if you ran open you would run a bit lean right???</TD></TR></TABLE>
bingo, you're correct
better to be rich than lean
I had to re-tune my car when my catalytic converter was removed. That may help you with your question. I'm running Hondata as well
Guest
Posts: n/a
Re: Dyno Tune and then exhaust system (PolySquared)
Well how about this, right now im running a hollowed out stock cat. and 2.25 cat back. Im getting a 3" car sound cat and 3" exhaust system. That should pretty much cancel out right? lol I know dumb question, but Im wondering b/c spending 100 bucks a pop and retuning EVERY time I add a part gets rediculous.
Wow, time for a new tuner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">
better to be rich than lean</TD></TR></TABLE>
Thanks Mase!
Thanks Mase!
