oil spraying out fo turbo lines? HELP FAST
oil spraying out of turbo lines? HELP FAST
we took off the turbo and downpipe to weld the dump tube off the wastegate to the downpipe, and re-installed everything just like we hade found it with ne gaskets and all. everthying was peachy till we drove about 20 minutes down the highway and oil started sparying out of the top or bottom of the turbo. im thinking it is iether the oil feed or return line, i do not know how much oil pressure you have on the oil return line, but it had enough pressure to hit the radiator. is there anything special you should use on the oil line fittings when re-installing them, teflon tape? other suggestions?
Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si »</TD></TR><TR><TD CLASS="quote">no teflon tape on AN fittings but on pretty much everything else with normal threads</TD></TR></TABLE>
CivicDude2k4
09-05-2006 08:24 PM
