Fitting to replace black breather box question >>
Old Jun 12, 2004 | 08:16 AM
platinum00's Avatar
Default Fitting to replace black breather box question >>
ok the black breather box on the back of a d16y8, use for the pcv system.
if im removing that, and using one of these plugs
how do i get the plug to stay. epoxy, or what.
thanks
platinum.
Old Jun 12, 2004 | 08:36 AM
buck02's Avatar
Default Re: Fitting to replace black breather box question >> (platinum00)
use a freeze plug or z-10 makes a block plucg that goes in the place of the black box thats what i used and use the both fittens in place of the back plugs with allen looking heads on them
Old Jun 12, 2004 | 08:38 AM
TurboJesse
Guest
Posts: n/a
Default Re: Fitting to replace black breather box question >> (buck02)
you may have a problem with those fittings...I have those fittings along with the fittings that came in my endyne kit and they are different. The endyne ones are modded with some sort of siphon tube..
Old Jun 12, 2004 | 09:42 AM
RenoRacing's Avatar
Default Re: Fitting to replace black breather box question >> (Mpir3)
Those fittings you have pictured aren't for the hole left by the black box. the single hole where the black box is/was needs a freeze plug hammered into it. Those fittings are for the two large allen head plugs in the back of the block.
Old Jun 12, 2004 | 05:26 PM
platinum00's Avatar
Default Re: Fitting to replace black breather box question >> (RenoRacing)
i dont have any alen head screws on the back of my block.
i have oil pressure sensor, water temp sensor, oil filter, black box, and coolant plug with 3/4 head.
if i wanna remove the black box. wtf do i do. , do thy make a plug with a fitting on the end like the one i have above. if so where do i get it at..
this on a 2000 d16y8 block
platinum.
Old Jun 12, 2004 | 06:15 PM
RenoRacing's Avatar
I don't have any experience with any d series blocks but b series blocks have two large(14mm) allen head plugs that you unscrew and then thread the two fittings you have shown above into. I've heard of drilling and tapping your crankcase for those fittings or similar endyn fittings. another reason to go b series.
Old Jun 13, 2004 | 08:16 AM
platinum00's Avatar
yea i guess i will just swap, since i cant use the fittings. haaha. or not
ttt
platinum.
Old Jun 14, 2004 | 06:22 AM
platinum00's Avatar
bump
Old Jun 15, 2004 | 12:59 PM
platinum00's Avatar
so know one with a sohc has replaced there pcv system , and removed this black box..
platinum.
portenio78
Aug 18, 2009 06:59 PM
Kr4nG
Apr 7, 2009 05:27 PM
SIXTY-1HATCH
Dec 26, 2006 12:07 PM
vtecb20coupe
Jan 19, 2004 07:46 AM
96b18c
Jul 13, 2003 10:29 PM
