compression test
Old Jun 12, 2004 | 11:44 AM
RACEPAK's Avatar
Default compression test
hello everybody
how do i know if my engine compression is good for turbocharging ?
how much psi a stock d serise engine will peak?
what numbers should i get from the guy at the shop??
Old Jun 12, 2004 | 11:50 AM
95GSRTT
Guest
Posts: n/a
Default Re: compression test (RACEPAK)
stock compression should be like 260, if its below 200 you have to rebuild everything...
Old Jun 12, 2004 | 12:06 PM
RACEPAK's Avatar
Default Re: compression test (95GSRTT)
what compression is good on a d14a6 engine?
Old Jun 12, 2004 | 12:22 PM
boostedEJ2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">what compression is good on a d14a6 engine?</TD></TR></TABLE>
Do you mean a D16a6??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">stock compression should be like 260, if its below 200 you have to rebuild everything... </TD></TR></TABLE>
260psi would be a good number to hit on an 11:1+ compression motor...you're not going to hit that on a stock d-series. I just did a compression test on my stock B18C1 (10:1 compression and should be around 200psi) and blew 195 across all 4 cylinders. I'd search around and see what's common compression for a6's...I'm sure someone's got to have done it...that's just my $.02.
Old Jun 12, 2004 | 12:48 PM
95GSRTT
Guest
Posts: n/a
Default Re: compression test (95gsrcivic)
ya i knew that, i was just giving him a hard time, since you could find that pretty easily just by searching. You aint gonna hit 260 on just about any stock honda car.
Old Jun 12, 2004 | 01:29 PM
RACEPAK's Avatar
i ment a d14a6
its a euro si model
I-4
Jun 10, 2007 08:57 AM
XstouterX
Feb 26, 2006 03:06 PM
dohcter g
17
Mar 23, 2005 07:47 PM
mjrage
12
May 28, 2004 03:20 PM
DOHCarp
Sep 11, 2003 07:10 PM
