Greddy Blue Box questions.
All right, I have a JDM 2nd Gen B16 in a 94 civic Si. I bought a turbo kit off an OBDII GSR. I will be using RC 310 injectors. My questions are:
1. Will the blue box work since it was from an OBDII car?
2. Does the blue box replace the need for a missing link, or do I still need one?
3. How do I wire it up. I have seen this diagrham, but thats for a 92-95 civic w/ a single cam I assume. Are the wires still the same for my DOHC?
Re: Greddy Blue Box questions. (311)
-Some people say it works. I say it does not from personal experience. It worked when not in high rpm but would throw a code 16 (injector failure) when under boost in high rpm. I'm thinking the OBD2 blue box does something to the injectors that the OBD1 ecu doesn't like.
-No missing link needed. Blue box blocks the map from seeing boost.
-Do a search for the diagrams. I came across at least a couple a few weeks ago.
Hope this helps.
No the blue box will not work in a OBDI car.
the Si blue box will not work right for a GSR.
so you using the GSR blue box in combination with OBDI = bad idea
If the blue box worked with OBDI cars then greddy wouldn't put 96-99.
