Project Big Block Compression Test.....
Old Jun 13, 2004 | 07:06 PM
ladysman's Avatar
Default Project Big Block Compression Test.....
I am speechless. When Carl (The lonely sole helping me in this project) screamed like a 12 year girl getting her period the first time, I thought, "Now What". His little scream, ended up being a good thing......at least I think it is?
In order from #1-#4. Also, Number 1 read like the others on a second try. We did it again since the number was lower but it got better (270)
Cyl #1
Cyl #2
Cyl #3
Cyl#4
And for all the non-believers, we took a vid of it.
Old Jun 13, 2004 | 07:10 PM
B18C1CYA's Avatar
Default Re: Project Big Block Compression Test..... (ladysman)
wow whats your cr ratio, that seams realy high or is it just me
Old Jun 13, 2004 | 07:12 PM
rjardy's Avatar
Default Re: Project Big Block Compression Test..... (B18C1CYA)
that is some retarded high compression.
Rob
boostismycrack's Avatar
E-thug
how many cranks was that?
B18C1CYA's Avatar
Default Re: Project Big Block Compression Test..... (rjardy)
my ratio is 9.1 and mine is like 180 ish
Old Jun 13, 2004 | 07:14 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">that is some retarded high compression.
Rob</TD></TR></TABLE>
Exactly my thought. I am not even sure this is a "Good Thing".
Anyway, I can't remember how many cranks. I would have to ask Carl (Demigod here). I will post the video when I can keep my eyes open long enough to do it.
Finaly compression according to Endyn is around ~9.6-9.8.
Old Jun 13, 2004 | 07:17 PM
B18Flip's Avatar
.....that's awesome man. Goodluck w/ the project
B18C1CYA's Avatar
i know a stock gsr should read those numbers so you got some high compression the way it looks
Old Jun 13, 2004 | 07:19 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">i know a stock gsr should read those numbers so you got some high compression the way it looks</TD></TR></TABLE>
Can't be all that high with flat top pistons.
Old Jun 13, 2004 | 07:21 PM
B18C1CYA's Avatar
well not shure did you have your head shaved or any thing ,what is the piston hight set at?
Old Jun 13, 2004 | 07:22 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">well not shure did you have your head shaved or any thing ,what is the piston hight set at?</TD></TR></TABLE>
Head wasn't shaved but resurfaced a little by Endyn to make sure it was straight.
Not sure on height as Endyn built the block. At least I didn't check anything on that?
Old Jun 13, 2004 | 07:23 PM
Suprdave's Avatar
no way thats 9:1...9:1 SOHC i have done are 175-190psi...depending on cam.
Old Jun 13, 2004 | 07:27 PM
ladysman's Avatar
Default Re: Project Big Block Compression Test..... (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">no way thats 9:1...9:1 SOHC i have done are 175-190psi...depending on cam.</TD></TR></TABLE>
It has the big Zex cam in it. I am thinking more like 10.5
I guess, I will need to be conservative with the tune huh?
B18C1CYA's Avatar
well you will not need much boost to make sick power
Old Jun 13, 2004 | 07:32 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">well you will not need much boost to make sick power </TD></TR></TABLE>
God, I can only dream.
Old Jun 13, 2004 | 07:39 PM
Suprdave's Avatar
270 psi is more than 10.5
Old Jun 13, 2004 | 07:40 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">270 psi is more than 10.5</TD></TR></TABLE>
Then what is it? Any idea?
Also, this motor only has 15 miles on it with ND oil. Make a difference? Maybe a little tight?
Old Jun 13, 2004 | 07:47 PM
D-Man's Avatar
Did you do the compression test with the throttle plate open?
Old Jun 13, 2004 | 08:38 PM
FredoSP's Avatar
Default Re: Project Big Block Compression Test..... (D-Man)
time for a leakdown test...
As for mine .. approx 9.3:1 C/R
I got 215-220 psi per cylinder and 2%-3% leakdown (Thanks Chris @ NRG). Endyn
Old Jun 13, 2004 | 08:42 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
Also, this motor only has 15 miles on it with ND oil. Make a difference? Maybe a little tight?</TD></TR></TABLE>
Well I was at 220-230psi across the board with the SRP 10.5:1 pistons. I calculated compression out to be closer to 10:1 though.
Old Jun 13, 2004 | 08:44 PM
Toymanf's Avatar
Default Re: Project Big Block Compression Test..... (RyanCivic2000)
Has your gauge been giving you normal #s on other motors?
270 sounds pretty high. Do you have access to another gauge to verify?
Frank
Old Jun 13, 2004 | 08:47 PM
MachAF's Avatar
have you tried a second compression tester to see the results?
Old Jun 13, 2004 | 09:08 PM
dunkd's Avatar
270 is REALLY high
Old Jun 13, 2004 | 09:20 PM
Sinner's Avatar
cr of 9.2 with 210psi does that sound normal?
Old Jun 13, 2004 | 09:22 PM
RyanEJ8's Avatar
Default Re: (Sinner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">cr of 9.2 with 210psi does that sound normal?</TD></TR></TABLE>
Sounds a little high. I would expect 170-190 psi.
