compression test results in.
Old Jun 13, 2004 | 01:55 PM
Ls-Rturbo's Avatar
Default compression test results in.
damn I just did a compression test on my 99Ls turbo I got 175-155-?-160 my #3 spark plug is like striped or stuck in because it was so had to twist out that I need a braker bar to turn it (not brake it lose). when I first got my turbo installed my compression was 205across.
Old Jun 13, 2004 | 01:57 PM
Ls-Rturbo's Avatar
Default Re: compression test results in. (Ls-Rturbo)
oh how can I fix the stuck spark plug? Im pritty shure it is stripped or the threads are messed up. is the head trashed?
Old Jun 13, 2004 | 02:42 PM
ImAcracker's Avatar
Loved
You can helicoil the spark plug hole. And you will want to pull the head for that.
Old Jun 13, 2004 | 03:03 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls-Rturbo &raquo;</TD></TR><TR><TD CLASS="quote">damn I just did a compression test on my 99Ls turbo I got 175-155-?-160 my #3 spark plug is like striped or stuck in because it was so had to twist out that I need a braker bar to turn it (not brake it lose). when I first got my turbo installed my compression was 205across. </TD></TR></TABLE>
205 across for an LS is abnormal i believe.. helms i think says a fresh/brand new b18b should be no higher then 200... 180 is a healthy/well maintaned engine... your numbers seem pretty inconsistent as is . the 175 .. then the 155 .. thats a 20 psi difference, could be a problem there... try a leak down test and see what the results are
Old Jun 25, 2004 | 07:27 AM
TYPERman2001's Avatar
* B A N N E D *
Default Re: compression test results in. (J337_UNIT)
hahah u prolly melted piston #3 lol
Old Jun 25, 2004 | 07:47 AM
carbonDelSol's Avatar
Default Re: compression test results in. (TYPERman2001)
Why do you way that, he said he could do the test cause the plug is cross threaded or something....
Old Jun 25, 2004 | 09:36 AM
TwoK4drSi's Avatar
Dude man, that's not funny.
Luck6
24
Jun 13, 2015 04:50 PM
NegativeXero
11
Aug 18, 2006 06:52 PM
iHOPEyouCHOKE
Apr 27, 2006 04:44 PM
iHOPEyouCHOKE
Apr 21, 2006 06:40 AM
