Help, Installing turbo...
Old Jun 15, 2004 | 05:22 AM
StolenTeg's Avatar
Default Help, Installing turbo...
Where is the water by-pass hose that greddy instrustion say to connect to the throttle body.
Instruction said: Install the water by-pass hose from the water by pas tube to the throttle body.
Where is there water hose and connect to which one at the throttle body... Help ASAP, picture would be great.
Old Jun 15, 2004 | 06:54 AM
MiraiZ's Avatar
Default Re: Help, Installing turbo... (StolenTeg)
not trying to be an ***, but shouldn't you have researched all that before you started?
Old Jun 15, 2004 | 11:40 AM
StolenTeg's Avatar
Well since i dont know, can anyone help me out a bit???
Old Jun 15, 2004 | 02:14 PM
StolenTeg's Avatar
Anyone know this???
and is there any trick on removing the oil switch bolt on the left of the oil filter, i got the black plastic off but no space to get the bolt out???
Old Jun 15, 2004 | 02:40 PM
bluebullet's Avatar
are you talking about the fitting where you tap the oil feed?
Old Jun 15, 2004 | 03:27 PM
StolenTeg's Avatar
Default Re: (bluebullet)
Yeah, But i got it already, Now what i need to know is the what greddy mean when they say Install the water by-pass hose from the water by pas tube to the throttle body. and where are those located, only thing i ned now is that and the blue box and im done... ZZzzzz
Old Jun 17, 2004 | 11:52 AM
bluebullet's Avatar
Default Re: (StolenTeg)
is it a water cooled turbo??? wtf
Old Jun 17, 2004 | 11:58 AM
sporkcrx's Avatar
You can run it without the water lines hooked up. So if you really want them installed you can do it later, or the next month like I would
imationdawg
Apr 19, 2011 08:14 AM
1ludeEK
Oct 2, 2007 03:32 PM
Jerm982
Mar 16, 2006 08:55 AM
xtremeness101
Aug 28, 2005 09:38 PM
jdmotorsports
Jun 4, 2003 10:06 AM
