2.5 Bar Mounting
Old Oct 21, 2005 | 05:15 PM
discrete's Avatar
Default 2.5 Bar Mounting
Please show me how you have your Motorola 2.5 BAR MAP sensor mounted.
Currently I have it mounted near the firewall with a line going to it, but thats not working out. Please, please, please show me how you have it mounted.
Thanks
Old Oct 21, 2005 | 05:58 PM
ccivic's Avatar
Default Re: 2.5 Bar Mounting (discrete)
I have mine ziptied to a vacuum line.
Old Oct 21, 2005 | 06:00 PM
discrete's Avatar
i'm most interested in how you soldered the 3 pins together
Old Oct 21, 2005 | 09:13 PM
nfn15037's Avatar
Default Re: (discrete)
I made a short pigtain and soldered the wires to an ORM MAP sensor that I cut up. This allows full plug and play. Icoated all of the solder joints in Hondabond to prevent corrosion.
Old Oct 22, 2005 | 02:03 AM
sohc_turd's Avatar
Default Re: (nfn15037)
you can pretty much put it anywhere... get creative. ive seen them in the fuse box, in-cab under dash, wrapped up in a ball of electrical tape... like i said, get creative.
Old Oct 22, 2005 | 01:00 PM
ccivic's Avatar
I used a method that Blundar told me to do.. got a molex connector (yes.. computer power connector) and got some smaller wire and carefuelly soldered and heatshrinked each soldered connection. I have the smaller wire connected to the pins (extra 3pins were snipped off) then the other end of the smaller wire to the wires going into the molex connector. This way with the molex connector, if for some reason I had to switch back to stock MAP sensor, all I have to do is unplug the Motorola and plug in the stock plug.
Just take your time and don't overheat the sensor.
P.S.: Tin the wire before you solder onto the sensor.
redlsvtec4door
Nov 4, 2007 08:57 AM
92redhatch
Jan 12, 2007 01:25 PM
Topdawgg
Jun 27, 2006 03:57 PM
O16581724 5 2 5
Nov 16, 2005 09:10 AM
BuiltB18C1
Oct 15, 2003 08:39 AM
