Mounting FMIC...no brackets?
Old Oct 21, 2005 | 09:11 AM
JDM00SI's Avatar
Default Mounting FMIC...no brackets?
sup,
im in the process of mounting my precision medium FMIC...for those of you that run it did you guys cut your bumper support? im installing it ona 2000 si...
well, i dont have the tabs to keep it hung up...therefore i was thinking of welding it. the fmic is thin aluminum..my buddy said he knows someone that can weld aluminum.....
What should i do to mount it?
cliff notes;
did you cut bumper support for precision medium....
What did you do to mount it?
thanks
Old Oct 21, 2005 | 09:12 AM
JDM00SI's Avatar
Default Re: Mounting FMIC...no brackets? (JDM00SI)
bump
Old Oct 21, 2005 | 09:21 AM
boostedcivicsir's Avatar
Mr. Badwrench
weld some tabs on it and cut the support accordingly. i know this is my eg but you can see what it looks like.
yes i am a picture *****
Old Oct 21, 2005 | 09:22 AM
JDM00SI's Avatar
isnt is hard to weld it due to the thin aluminum...?
Old Oct 21, 2005 | 09:30 AM
Mr. Badwrench
Default Re: (JDM00SI)
any machine shop that knows how to tig weld should be able to handle it.
Old Oct 21, 2005 | 11:33 AM
pimpintyperintegra's Avatar
definitely get someone who is experienced with welding aluminum to make you some brackets and weld them on...welding aluminum requires an entirely different method of welding than steel and you use aluminum filler also
if you are familiar with TIG welding and have access to the equipment, then you could do it yourself if you like
then cut the bumper support to fit the intercooler properly
then you're good to go
Old Oct 21, 2005 | 04:29 PM
speeddave's Avatar
Default Re: Mounting FMIC...no brackets? (pimpintyperintegra)
the medium precision intercooler should come with threaded holes in the sides of the intercooler at the top. you can use those holes, and fab up some simple brackets that bolt to the front of your car.
Old Oct 21, 2005 | 07:00 PM
Black DC2's Avatar
Default Re: Mounting FMIC...no brackets? (speeddave)
I used 2 L brackets from home deput to mount it. Works just fine and just cut out the bumper support a lil
here is a pic but mine is not upside down just to give ya and idea
search button does work
https://honda-tech.com/zerothread?id=1070561
Old Oct 21, 2005 | 07:24 PM
m R g S r's Avatar
Default Re: Mounting FMIC...no brackets? (Black DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black DC2 &raquo;</TD></TR><TR><TD CLASS="quote">I used 2 L brackets from home deput to mount it. Works just fine and just cut out the bumper support a lil
https://honda-tech.com/zerothread?id=1070561</TD></TR></TABLE>
EXACT **** i did....
Old Oct 21, 2005 | 10:10 PM
adictionbass's Avatar
Default Re: Mounting FMIC...no brackets? (m R g S r)
heres the best pic i have of what i did...
bbrian
Nov 4, 2005 12:31 PM
JDM00SI
Oct 27, 2005 12:21 PM
O16581724 5 2 5
14
Jul 2, 2005 06:15 PM
.ShawnD.
Oct 6, 2004 11:37 AM
ludetech
Sep 5, 2004 07:15 PM
