Timing too advanced?
I have a t3 60trim on B18C1 with uberdata.
Timing is 17.25 (low cam) and 23.25 (hi cam) from 5k upward @ 10 psi. Anyone running similar timing? Is this conservative enough?
I don't wanna blow my engine (yet!)
that's quite a bit. Low cam is conservative and hi cam is a bit aggressive without a dyno. I'd stay around 19-20 without a dyno. 21 if you know how to check everything. Check your plugs frequently at first for any signs of detonation and to see if the ground strap is correct
thanks for the reply!
I guess maybe I am running too aggressive. Anyone else?
This is my plugs:
https://honda-tech.com/zerothread?id=1407600
This is my plugs:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 »</TD></TR><TR><TD CLASS="quote">on boosted cars at 10 psi i set timing to 19*</TD></TR></TABLE>
Now I'm a lil worried
I'm gonna have dyno day on sunday, got 3 pulls, what are some of the timing you suggest me to run.
Btw, when you say 19* it's for hi cam right?
yup 19* high cam timing. try 19* first then when ur on the dyno add 1 * timing, if the TQ increases then try to add another 1/2 - 1 degree. once the tq does not increase, back off the timing by like 2* to keep the motor safe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 »</TD></TR><TR><TD CLASS="quote">ehhh im set at 26º at full boost</TD></TR></TABLE>
if the motor is built w/ low compression pistons and/or bigger displacement than 1.8liter, then i say 26* aint that bad. but for a stock motor, 26* at 10psi seems a bit too much timing
what psi?
Did someone tune it for you?
what psi?
Do a pull.. shut off around 5500 rpms and pull the plugs.. see if there's any specks of anything on them. If there is.. back off the timing and do it again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 »</TD></TR><TR><TD CLASS="quote">AMS-Tuning set everything for me, we only did street tuning. I should prob go look at the plugs</TD></TR></TABLE>
well it cant be that bad, pending on how many miles you have ran, your motor hasnt blown YET!
Ok. So for Hi cam, I will start from 19* on the dyno.
I wonder whether the low cam matters at all beyond vtec transition, but how much timing do you guys run @10 psi?
So you just arbitrarily set all turbo'd Honda's to 19* BTDC @ 10psi eh?
