what do you think of my potential set up??
dohc zc, tuner toys (d-series rods), srp pistons w/.10 overbore(for a z6), thicker headgasket, arp head studs. and i plan on runnin a t3 turbo (i know tuning is a big part of it), dsm injectors(440cc), pr4 ecu with turbo edit, 2.5"pipping and a 5" jrc front mount........ but about how safe would that set up be? about how much boost could that set-up handle?? and what would be a safe hp level?? thanks for any help
Re: what do you think of my potential set up?? (hatchinprogress)
how come your running such a small turbo? personally id go with the garrett t3/t4 turbo for your set-up. depending on tuning you should expect between 400-450 hp but im not exactly sure on the dohc zc. its just a guesstimate
Re: what do you think of my potential set up?? (CRX_Phantom1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Phantom1 »</TD></TR><TR><TD CLASS="quote">how come your running such a small turbo? personally id go with the garrett t3/t4 turbo for your set-up. depending on tuning you should expect between 400-450 hp but im not exactly sure on the dohc zc. its just a guesstimate</TD></TR></TABLE> well i was thinking of a bigger turbo, but since i think im not going to sleeve the block i thought i would be a lil more conservative.
does anyone know if this set up could safely handle 400hp??
Re: (AbitAvenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger »</TD></TR><TR><TD CLASS="quote">i dont know about 400-450 hp with a t3...
maybe 400 on a great tune t3/t4...
sounds like a fun project though</TD></TR></TABLE> im tryin to find out if the engine/block could handle that kind of hp...... ill worry about getting it later.
what would be a safe amount of power could my set up handle(not make)??? would it be safe @300hp???
Re: (hatchinprogress)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote"> im tryin to find out if the engine/block could handle that kind of hp...... ill worry about getting it later.
what would be a safe amount of power could my set up handle(not make)??? would it be safe @300hp???</TD></TR></TABLE> anyone???
Location: The Village Hidden in the Leaves: Seattle, WA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote">dohc zc, tuner toys (d-series rods), srp pistons w/.10 overbore(for a z6), </TD></TR></TABLE>
you have a dohc zc and you'r gonna put in z6 pistons? will that work?
anyways, i don't know about 300hp on a t3, but i'm sure it could happen with a super good tune. maybe look into the t3 super 60? or just get a .48a/r t3/to4e. what's the length on the jrc 5inch? you might wanna go with the new jrc 6inch for a bigger hp application.
Re: (CRX_Phantom1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Phantom1 »</TD></TR><TR><TD CLASS="quote">you should be fine with 300 if your running the t3</TD></TR></TABLE> plaes diregard the turbo info (im not askin how much power i can make) i want to know how safe my block will be with this potential build<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 »</TD></TR><TR><TD CLASS="quote">
you have a dohc zc and you'r gonna put in z6 pistons? will that work?<U></U>
anyways, i don't know about 300hp on a t3, but i'm sure it could happen with a super good tune. maybe look into the t3 super 60? or just get a .48a/r t3/to4e. what's the length on the jrc 5inch<U></U>? you might wanna go with the new jrc 6inch for a bigger hp application.</TD></TR></TABLE> yeah the z6 pistons will work (<U>most</U> d-series pistons are interchangeable) and the intercooler is the same length as the 6" (just 5" tall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote"> plaes diregard the turbo info (im not askin how much power i can make) i want to know how safe my block will be with this potential build </TD></TR></TABLE>
i'm sure most would say safety is in the tune....sure.
Re: (undercoverdc2)
i'm sure most would say safety is in the tune....sure.</TD></TR></TABLE>thanks
xTyReaper
04-14-2010 08:04 AM
hatchinprogress
10-18-2005 12:58 PM
