//// 450 install on a obd2 motor... Can't find the dead plug. ////
I have done the obd1 install before but the dead plug was up in the drivers side corner. I now own a 99 si and there is no dead plug there. I have found this post https://honda-tech.com/zerothread?id=577749 ) but is seems like lot of work. So my question is: Is there a dead plug on my civic si and where is it. Also is there a link that I can't find that explains all of this. Wish it was as easy as it is on the obd1 cars.
Please help.
Please help.
Re: //// 450 install on a obd2 motor... Can't find the dead plug. //// (warrick)
what does it look like... is it the same as the obd1 dead plug? How man wires go to it.
Re: //// 450 install on a obd2 motor... Can't find the dead plug. //// (crx616)
its big and gray. it has 5 wires connected to it. 4 of them are yel/blk and one is red,
its under the IM.
its under the IM.
Re: //// 450 install on a obd2 motor... Can't find the dead plug. //// (RACEPAK)
So I take out those four wires and put them into the resistor box plug. and then I take the extra wire from the resistor box and put that into the dead plug right.
mmm... i dont know... i evantualy decided to use inline resistors . its a major pita to wire it there if the intake manifold is installed.
Don't even bother finding it.. I found it, wired it up and found out that the wiring is different.. don't mess with that. Open up the fuel injector harness holder thing and cut all four power wires (Yellow/Black). Wire the four black wires on the resistor box to the Yellow/Black wires you just cut going to the injectors. Twist all of the four Yellow/Black wires coming from the power source together and to the red wire on the resistor box. Make sure you solder and properly heatshrink/e-tape all of your connections and make it clean.
THE END. Tested and approved.
