Turbo Help PLEASE
hi, what do u think of this turbo? is it good for 500hp (with nos 75 shots dp) drag use car?
GARRETT T3/T4
Turbine specs:
T3 6 bolt outlet turbine housing .83 A/R
76 trim T350 turbine wheel (stage 5)
Compressor Specs:
T04E housing 2.5" inlet 2.5" outlet
56 trim GT40 compressor wheel 2.41/3.22 (61mm inducer) and flow 65lb/min
Divided Turbo Flange
The compressor wheel that this turbo have is a GT40 the same compressor wheel that have the new Garrett GT35R. This compressor wheel is from the new technology of Garrett. Also this turbo have the latest bolt down 360 degree thrust bearing desing. This essential design ensures a long life, even under the most brutal racing conditions.
Modified by SpiderSol at 1:24 AM 10/17/2005
GARRETT T3/T4
Turbine specs:
Compressor Specs:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubs »</TD></TR><TR><TD CLASS="quote">Are you sure thats a real garrett? It looks like it has a generic compessor housing on it = cheap knock-off.</TD></TR></TABLE>
whay do u mean by generic compessor housing ...
i'm intersted to know about this turbo too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiViC SiR »</TD></TR><TR><TD CLASS="quote">
i'm intersted to know about this turbo too</TD></TR></TABLE>
There are a bunch of turbos floating around on ebay that are cheap garrett knock-offs. They're usually made in china and tend to fall apart. I think SS Auto Chrome sells them (or at least they used to).
yeah thats pretty shitty if its from ebay i work at a turbo shop and this guy brought in his turbo off of ebay it was totaled within 5 minutes after it was installed it looked like shitty balancing and they seem like a buch of clowns who put it together and pray it works go with a REAL garrett. GT series rock too Ball bearings!
underpressure02
Feb 10, 2004 07:26 AM
