who has experiance installing arp headstuds without removing the head? jdm d15b
I remember reading a while back that a few members installing arp headstuds without removing the head. for those who did, how is your car running now? and what method did you use to install the studs? this is for a 95 civic ex with jdm d15b. thanks in advance
Moderator in Chief
Re: who has experiance installing arp headstuds without removing the head? jdm d15b (91integraLSVTEC
There are only 2 reasons why someone would want to add head studs to their motor.
1.) Their head has lifted and their head gasket is blown.
2.) They want to prevent 1.)
If you are #1 then you need remove the head anyways to replace the head gasket. If you are #2 then by replacing the head bolts with studs WITHOUT REMOVING THE HEAD will compromise your head gasket integrity and turn you into #1.
Dont ghetto it. Do it right.
did it to mine as well
removed oem and installed arp one by one according to the INSTALL seq
but the problem was my hg was already blown, i was to late
DelSol-B18
09-08-2012 06:24 PM
EJ1 wilcox
02-23-2006 03:08 PM
