Average egt's at idle
Old Oct 20, 2005 | 07:31 PM
livinlow's Avatar
Default Average egt's at idle
What are everybody's egt's at idle? More of a is my gauge working right question. Thanks. I searched and it's all the same, is this too high?!?!
Old Oct 20, 2005 | 07:35 PM
elpiar's Avatar
Default Re: Average egt's at idle (livinlow)
800 F
Old Oct 20, 2005 | 07:42 PM
livinlow's Avatar
Default Re: Average egt's at idle (elpiar)
Damn, my gauge may be f'd up, I'm only getting 500F or so, a/f at 15 to 15.5, aem wideband. my probe is mounted in the internal gate hole in my d/p 5 bolt flange.
Old Oct 20, 2005 | 09:16 PM
Dunc's Avatar
BCICAN
800ish, I also idle at 1200rpm.
Old Oct 20, 2005 | 09:50 PM
adictionbass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by livinlow &raquo;</TD></TR><TR><TD CLASS="quote">Damn, my gauge may be f'd up, I'm only getting 500F or so, a/f at 15 to 15.5, aem wideband. my probe is mounted in the internal gate hole in my d/p 5 bolt flange.</TD></TR></TABLE>
guessing this is his problem?
Old Oct 21, 2005 | 05:05 AM
mike1114's Avatar
Default Re: Average egt's at idle (adictionbass)
wow, mines like 450-600ish F
probe is in runner #3 1.5 inches from head.
Old Oct 21, 2005 | 06:22 AM
RacerXI's Avatar
Default Re: Average egt's at idle (mike1114)
410c...probe in manifold 1.5" from head...idle is 800-850
Old Oct 21, 2005 | 06:56 AM
Dunc's Avatar
BCICAN
Well the placement of the probe will have alot to do with what temps you read. Seeing as the turbo is a fairly large heat sink, the placement of your probe isn't exactly ideal which explains your variation.
Old Oct 21, 2005 | 06:57 AM
elpiar's Avatar
Where you mount your probe has great effect since the manifold and turbo is a big heat sink.
People say about 200F is a good approximate temp drop if you mount it on the DP flange. Mine is 800F, yours is 500F+200F so it's about 700F if you want to be on the same benchmark with people's opinion (cause most mount it 1.5" from head)
mortificationrock
Aug 22, 2008 11:13 PM
slodel
Jul 4, 2006 08:24 AM
screen_name
11
Nov 14, 2005 08:58 PM
XxRoCkMaNxNEOxX
Oct 24, 2004 09:03 AM
DEVIN22CBR
Mar 24, 2004 05:43 PM
