resistor box / dsm 450cc
Old Oct 19, 2005 | 03:41 PM
teddy_dc2's Avatar
Default resistor box / dsm 450cc
i was planning to run some dsm 450cc in my gsr-t set up. does it matter what resister box i use? can i use my stock o rings to put around the dsm injectors or i have no choice but to cut back the dsm o rings and make a fit?? can an amature do this without problems??
Old Oct 19, 2005 | 04:19 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: resistor box / dsm 450cc (teddy_dc2)
you need a total of 12-13 ohms of resistence through the circuit. so if your injectors are 2-3 ohms, you need another 10 ohms of resistence. i know if you are using separate radio shack resistors, you need 10watt 10ohm resistors.
evosix
Jun 4, 2008 06:41 PM
97ekb18b
May 27, 2008 08:04 PM
Happyman
Jul 7, 2003 06:37 AM
