throwing codes cant fix.need help
Old Oct 18, 2005 | 03:29 PM
jdm.ej's Avatar
Default throwing codes cant fix.need help
throwing code 43.3.1. i know what all the codes are.
43 fuel supply. what can that be. if you look a thec fuel gauge after the ignition off you can see the fuel pressure dropping slowly. the only thing i can think of is a bad fuel pump or a leak in the injectors which i cant see any leaks.
3 is the map sensor... its almost a brand new sensor def wired right.
1 is the o2 prob a bad o2 because i just rewired all of them today.
the codes will throw after a few minutes of driving. but as soon as the car turns off they go away.never a check eng at start up...
some advice would be appreciated.i dont think the map is becuase im boosting
because im not in boost most of the time.
Defiant_dc
Oct 12, 2008 08:29 AM
triple5soul8781
Aug 24, 2008 06:24 AM
Primetime2628
Jul 17, 2004 05:10 AM
shivic
Apr 23, 2004 11:20 AM
Sohc Driver
Sep 21, 2003 11:05 AM
