Clutch doesn’t fit WTF?
Ok I my trans is from a jdm interga xsi 92-93 cable YS1. I have been running a act 6 puck and a stock clutch from a 93 jdm b16a with no problem ( well I hated the six puck and the stock disc exploded, but they fit) I ordered a CM 300 segmented Kevlar clutch for a 92 teg. Its too small, the ******* tranny would not go in and after wrestling with it for a while I pulled it off and put a micrometer on it.
ACT 6 Puck = 1.02ish”
CM Kevlar = >1”
Both have 24 splines if you count the inner apexes of the splines , what gives?
ACT 6 puck
CM300 Kevlar
CM Kevlar = >1”
ACT 6 puck
CM300 Kevlar
Re: Clutch doesn’t fit WTF? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">you have a big input shaft... they sent you a clutch for a small input shaft</TD></TR></TABLE>
thats simple as that the 90-91 used the samll shaft vs the 92-up all large shaft similar with the b16a discs some are larger some are small based on year
Re: Clutch doesn’t fit WTF? (abnaasefmb)
just so people know,
the good people at Horsepower Freaks dot com namely josh. (where i have spent literality thousands of dollars) told me to go expletive myself. won't be using them anymore!
i call Clutch Masters and they said no problem and gave me a return number and i shipped it out today.
i have to give clutch masters a big
and these guy are no longer in my favoriteshttp://www.horsepowerfreaks.com/
Anyone with an S1 tranny and upgraded clutch/flywheel? I have a question for you (Or if you might kn
Fred n J_v2.0
15
07-24-2003 05:21 AM
stockcrx
03-05-2003 06:36 PM
B20zvtecek
09-07-2002 11:40 AM
