Oil weight question?
Old Oct 21, 2005 | 06:05 AM
Specail Ed's Avatar
Default Oil weight question?
I'm getting ready to turbo my H22. I was just wondering what weight oil you boosted guys are running.
Old Oct 21, 2005 | 06:11 AM
The Weather Man's Avatar
i say stick with 5w30
and 10w40 in tranny
Old Oct 21, 2005 | 06:50 AM
11psiTurboSI's Avatar
Default Re: (TheKingPin)
10w-30
Old Oct 21, 2005 | 09:50 AM
whoneedzvtec's Avatar
Default Re: (11psiTurboSI)
i use 15-50 in the middle of the summer when its really hot and 10-30 in the winter.
Old Oct 21, 2005 | 10:05 AM
vtec.dc2's Avatar
Default Re: Oil weight question? (Specail Ed)
20w50 or 15w50 during summer
i run a mix of 5w40 and 15w50 or 5w40 20w50 during spring and fall
right now switching to 5w40 to run during winter
Old Oct 21, 2005 | 10:37 AM
93H22ACX's Avatar
Default Re: Oil weight question? (vtec.dc2)
20w50 during summer and 10w30 for the winter
Old Oct 21, 2005 | 10:54 AM
Supercow's Avatar
Default Re: Oil weight question? (93H22ACX)
I always use 10w-30 year round
Old Oct 21, 2005 | 10:58 AM
mike1114's Avatar
Default Re: Oil weight question? (Supercow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93H22ACX &raquo;</TD></TR><TR><TD CLASS="quote">20w50 during summer and 10w30 for the winter</TD></TR></TABLE>
Drag turbo install kit even recommends 20w50.
Old Oct 21, 2005 | 11:16 AM
Rory Breaker's Avatar
Default Re: Oil weight question? (mike1114)
20w50 is WAY too thick. Good god.
I run 5w30 year round. About to change to German Castrol 0w30, full syn base, heavy 30w (almost a 40) and excellent flow on startup. Should be perfect for my driving conditions and climate.
Old Oct 21, 2005 | 11:17 AM
The sweed's Avatar
stright 50 oil LE engineering Not a oil for cold wether
Old Oct 21, 2005 | 01:41 PM
Default Re: Oil weight question? (The sweed)
Just curious, why do you guys run such thick oils? A straight 50? Why?
Old Oct 21, 2005 | 02:48 PM
Flashmn's Avatar
Default Re: Oil weight question? (Rory Breaker)
5W50 Mobil one in the engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and 10w40 in tranny</TD></TR></TABLE>
Motor oil in the tranny isnt doing the tranny any good. Tranny oils need different characteristics, such as surface tension. So motoroil in tranny
Old Oct 21, 2005 | 05:12 PM
planeman01's Avatar
some of the older honda tranny's require 10-30...my 90 prelude runs it, per helms manual
Old Oct 21, 2005 | 05:52 PM
EBP.EM1's Avatar
20w50 in summer, gonna switch to 10w30 for the winter
Old Oct 22, 2005 | 03:44 AM
Specail Ed's Avatar
Default Re: (slo4dr)
Thanks for the input. I myself think 50 weight sounds a little thick, but just wanted to see what others were doing. I think I might just something in the middle all year round.
Old Oct 22, 2005 | 04:41 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rory Breaker &raquo;</TD></TR><TR><TD CLASS="quote">20w50 is WAY too thick. Good god.
I run 5w30 year round. About to change to German Castrol 0w30, full syn base, heavy 30w (almost a 40) and excellent flow on startup. Should be perfect for my driving conditions and climate.</TD></TR></TABLE>
at some point 20w50 will be as thin as 30 weight, and thats about 10 degrees in temp drop to go from 50 to 40, i go by oil pressure, the way i switch between weights it stays about the same through all seasons.
when choosing oil i stay away from energy concerving oils, that would be most if not all 30 weights and maybe some 40 weight. the higher HTHS the more stable it will be at higher temps, and synthetic in general will offer more stability.
Old Oct 23, 2005 | 01:47 PM
But at startup it will be a 20w which for us, especially our turbo setups, is super thick. Not only that but why not just get a viscosity stable 30 or 40w @ temp if thats what you want to run?
When you say you stay away from energy conserving oils, do you mean you tend to go for oils that do not offer friction loss as a benefit because you do not trust that they lubricate and protect as well?
_Endless_
May 11, 2011 05:12 PM
lookout22
Apr 20, 2009 06:23 PM
FastLife617
40
Jun 5, 2007 01:37 PM
1.8Tities
Apr 18, 2003 02:35 PM
turbosi92
Jul 3, 2002 11:27 AM
