running lean at idle
Old Oct 16, 2005 | 01:29 PM
Argetnia's Avatar
Default running lean at idle
when i start my car cold my a/f's read 13.5-13.7. once the motor gets hot the gauge starts to jump from 14.0-16.1 back and fourth. this is on a ls motor using an aem uego gauge.
any ideas or input would be appreciated.
Old Oct 16, 2005 | 01:31 PM
mtber's Avatar
Default Re: running lean at idle (WEST*SIDE)
What fuel management system are you using ?
Old Oct 16, 2005 | 01:37 PM
Argetnia's Avatar
Default Re: running lean at idle (mtber)
im runing a stock ecu with fmu and inline pump. i know that the fmu sucks and i should ditch it. the a/f's were fine before. im just trying to get the little bugs worked out before i get it tuned.
Old Oct 16, 2005 | 01:49 PM
Muckman's Avatar
Moderator in Chief
Is this really a bug tho? Does it affect the idle? Thats not real lean for idle actually. I idle at 15.5 all day long.
Old Oct 16, 2005 | 01:53 PM
alpha's Avatar
Default Re: running lean at idle (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Is this really a bug tho? Does it affect the idle? Thats not real lean for idle actually. I idle at 15.5 all day long.</TD></TR></TABLE>
Every car is different but you are right. Most cars idle fine from 14:1 - 15.5:1. The only problem I see is it's fluctuating two full points at idle.
Old Oct 16, 2005 | 02:08 PM
Muckman's Avatar
Moderator in Chief
Default Re: running lean at idle (0x64)
I guess it depends on how fast its fluxuating. Is it over time as its warming up or back and forth every second or so? Could be caused by a misfire.
Old Oct 16, 2005 | 03:55 PM
Argetnia's Avatar
once its hot it fluctuates every second or so.
Old Oct 16, 2005 | 04:00 PM
Argetnia's Avatar
it does affect the idle.
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WEST*SIDE &raquo;</TD></TR><TR><TD CLASS="quote">when i start my car cold my a/f's read 13.5-13.7. once the motor gets hot the gauge starts to jump from 14.0-16.1 back and fourth. this is on a ls motor using an aem uego gauge.
any ideas or input would be appreciated.</TD></TR></TABLE>
That's all normal operation.
Old Oct 16, 2005 | 04:03 PM
Argetnia's Avatar
Default Re: running lean at idle (sharkcohen)
is this normal whils driving? once i hit boost it runs richer.
Old Oct 16, 2005 | 04:22 PM
vaporboy12's Avatar
every car will idle different injector size will play a part in this. i run 1000cc's my car not happy at idle unless its like 12.3:1 or so. a/f at idle really does matter there is no load on the motor
ncsi
Feb 9, 2012 02:06 PM
mouab18c1
Engine Management and Tuning
Sep 18, 2010 05:06 PM
mouab18c1
Sep 15, 2010 10:05 PM
Hyaboosta
Jul 13, 2005 02:14 PM
SSS2000
May 11, 2004 04:21 PM
