chip ecu and gm3bar map sensor
if you have a chip ecu for turbo to run on the stock map sensor which 11psi. would i need the chip reprogram to read the 3bar to run more boost or is it just setting a switch in the ecu. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKingPin »</TD></TR><TR><TD CLASS="quote">Stop being cheap - get a hondata s300 or something. You must want to mess up your motor. </TD></TR></TABLE>
i would have to agree. get it tuned correctly with the correct map for the 3 bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hulk22 »</TD></TR><TR><TD CLASS="quote">s200 comming in dec. </TD></TR></TABLE>
problem solved.
problem solved.
vtec.dc2
Feb 12, 2004 04:39 PM
