What engine management to use?
Old Oct 19, 2005 | 05:07 PM
Powered By Garrett's Avatar
Default What engine management to use?
Hey, i'm running a semi-ghetto, very cheap, turbo setup. I'm trying to find a cheap/free engine management setup. I heard CHROME was good, but can't seem to find it anywhere? Heres my setup:
95 Civic HB
00 Civic DX Engine
95 Civic SI Trans
Log Manifold
T26 Turbo
Galant IC Setup TMIC Style (For now, Just an experement)
Stock inj
Stock pump
FMU
Running 6lbs
YES! I know its ghetto. YES! It probobly wont last. I'm just trying to get a few good days of fun out of it. I'm going into the army, and when I get back in 4 years I have bigger plans, so I just threw this together for fun and games. I wanna see what kinda power I can make with it, so I need management, but as I said, only a few days worth, so I dont wanna play for Hondata. Thanks in advanced!
Old Oct 19, 2005 | 05:10 PM
NJIN BUILDR's Avatar
Default Re: What engine management to use? (EGtenchu)
http://www.pgmfi.org/
Old Oct 19, 2005 | 05:15 PM
Default Re: What engine management to use? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">http://www.pgmfi.org/</TD></TR></TABLE> ty
Old Oct 19, 2005 | 06:11 PM
ham's Avatar
ham
you got an FMU! what do you need management for! haha.
I normally would never say this, but in your case I would have to say you have 2 semi cheap choices.
A. PM somebody that deals with ECUs and get one thats chipped for your setup with a good basemap. (unless you can do it yourself.....?)
B. SAFC
Old Oct 19, 2005 | 06:19 PM
Default Re: What engine management to use? (ham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">you got an FMU! what do you need management for! haha.
B. SAFC
I actually just ordered a uberdata chip set. i'm gonna install that **** next week and take it to get dyno tuned.
Old Oct 19, 2005 | 06:22 PM
ham's Avatar
ham
get some dsm injectors and a resistor box
Old Oct 19, 2005 | 06:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">get some dsm injectors and a resistor box </TD></TR></TABLE>
Know of any? How much they usually go for?
Old Oct 19, 2005 | 06:28 PM
ham's Avatar
ham
search classifieds and classifieds forced induction for "DSM injectors"
let me know if you need to know how to install them.
Old Oct 19, 2005 | 06:31 PM
flip1199's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGtenchu &raquo;</TD></TR><TR><TD CLASS="quote">Hey, i'm running a semi-ghetto, very cheap, turbo setup. I'm trying to find a cheap/free engine management setup. I heard CHROME was good, but can't seem to find it anywhere? Heres my setup:
that's because it's spelled crome.
Old Oct 19, 2005 | 06:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">search classifieds and classifieds forced induction for "DSM injectors"
let me know if you need to know how to install them.</TD></TR></TABLE>
Yes I do. And do people usually sell just the resistor boxes? I think I can get ahold of some 1g auto turbo injectors from a buddy of mine, just just got the 5-speed ones.
Old Oct 19, 2005 | 06:34 PM
Default Re: What engine management to use? (flip1199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">
that's because it's spelled crome. </TD></TR></TABLE>
LOL! That would have helped! Thanks! Haha
Old Oct 19, 2005 | 06:37 PM
ham's Avatar
ham
you can get a res box from any junkyard. i found one on an 80s prelude.
Old Oct 19, 2005 | 06:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">you can get a res box from any junkyard. i found one on an 80s prelude. </TD></TR></TABLE>
What do they look like?
Otherwise I found one for $25 shipped, that a good price?
Old Oct 19, 2005 | 07:01 PM
ham's Avatar
ham
Otherwise I found one for $25 shipped, that a good price? </TD></TR></TABLE>
thats good, but it can be free!
Old Oct 19, 2005 | 07:10 PM
Hmm, spose it wont hurt to look.
Old Oct 19, 2005 | 07:26 PM
ham's Avatar
ham
you can even go to radio shack and get 4 10watt 10ohm resistors and put them in series of the yellow/black wires.
Old Oct 19, 2005 | 07:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">you can even go to radio shack and get 4 10watt 10ohm resistors and put them in series of the yellow/black wires.</TD></TR></TABLE>
what does the resistor box do, how do you hook it up?
Old Oct 19, 2005 | 07:47 PM
ham's Avatar
ham
92+ hondas have 12v being supplied to the injectors. obd0 and dsm injectors run on ~5.5V. they need 12v with a resistor to turn the 12v down to the lower voltage. The signal from the ECU is a pulsed ground, so voltage is constantly being applied.
The yellow/black (power) wires go to the resistor box, and the 4 wires coming out are the lower voltage wires, which will then go to the injectors.
to get the dsm injectors in you also need to dremel off a tiny tab on the inside of each injector and drill out your big flat o rings on the intake manifold
Old Oct 19, 2005 | 08:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">to get the dsm injectors in you also need to dremel off a tiny tab on the inside of each injector and drill out your big flat o rings on the intake manifold</TD></TR></TABLE>
scary
Old Oct 19, 2005 | 08:30 PM
Pay2play killa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote"> to get the dsm injectors in you also need to dremel off a tiny tab on the inside of each injector and drill out your big flat o rings on the intake manifold</TD></TR></TABLE>
not quite; you'll want to use the stock honda or dsm o rings in the fuel rail (whichever are bigger; i can't remember off the top of my head) and you have to bore out the injector to bung rubber piece; no actual dremeling on the injector.
they're a 75% drop in replacement for stock injectors
Old Oct 20, 2005 | 02:44 AM
93turbo16's Avatar
Default Re: What engine management to use? (Pay2play killa)
Actually on most cars you don't even have to dremel out the seals I have learned. Just take out the lower hard seal and leave the soft seal in there, i think tegs might be the only one with the two seals but I don't remember.
Then just take a razor blade and chop off the tab, and you are good to go. Plus the wiring of the resistor box.
Old Oct 20, 2005 | 03:41 AM
ham's Avatar
ham
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pay2play killa &raquo;</TD></TR><TR><TD CLASS="quote">
they're a 75% drop in replacement for stock injectors</TD></TR></TABLE>
on his car, he will have to cut the little tab on the inside of the injector plug. i found it easiest to use a tiny dremel bit, it saws it right off.
and as far as monster trucking the injectors into the intake manifold... good luck, its hard as hell. i think its easier to just bore out that bottom seal.
Old Oct 20, 2005 | 05:57 AM
G
sh!t happens.
Use the Hondata I have for sale..............
Old Oct 20, 2005 | 09:43 AM
Default Re: What engine management to use? (G"UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G"UNIT &raquo;</TD></TR><TR><TD CLASS="quote">Use the Hondata I have for sale.............. </TD></TR></TABLE>
Already going uberdata
Old Oct 20, 2005 | 10:23 AM
blundar's Avatar
If you're paying someone else to tune the car, use Crome. There is no difference in cost to the "end user" - the difference being the datalogging enabled version of Crome Pro costs tuners money. I can tune cars faster with Crome. I'm happier with the overall results. I think you will be too. Uberdata's strength is that it is a datalogging-enabled tuning application for those who have the tools and motivation to tune it themselves but don't have the cash for CromePro or Hondata. If you're paying someone else to tune the car, use better tools.
