GT35R v. T3/T67, which better for 400 whp?
I've come around to getting rid of my turbo setup I had intended to run on my Se-R and I'm looking to buy a bunch of new parts, including a new turbo. SR20Forum isn't much help when it comes to specific turbo information so I figured I would ask here.
How big is a difference between a GT35R and a t3/t67 with comparable specs? I've noticed a lot of people run the t3/t67 and make 400+, while most people I see with the GT35R are running in excess of 500 or more. Any reason for this?
I'd like to purchase either of these for my next setup, I just don't know how to read compressor maps or anything like that to compare. Someone shine some light on this for me
Re: GT35R v. T3/T67, which better for 400 whp? (2LiterTurboSeR)
If you can afford the gt35r go with that one... It is a bad *** turbo. I use to run the t3/t67 and it's a really good turbo aswell, but once you go ball bearing you won't go back.
I've seen dyno charts of both on almost identical setups. The torque curve, and hp are pratically the same up to a certain point. The gt35r just made the power sooner. Alot of people say that the spool is only like 700-800 sooner, but when you factor in the fact that it also makes 100 or so hp sooner. That's a big deal in my opinion.
Just my .02 cents. Good luck with your build.
Re: GT35R v. T3/T67, which better for 400 whp? (TurboChrgd_Civic)
I go with GT35R for the simple fact that it's fuggin nice and the exceptional efficient turbo it is. 10 second turbo.
Re: (flip1199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 »</TD></TR><TR><TD CLASS="quote">gt30r</TD></TR></TABLE>
No doubt!
No doubt!
Re: GT35R v. T3/T67, which better for 400 whp? (m R g S r)
the gt2871 is also rated to 400hp, but that would be maxing it out and might be pushing hot air at that point, but i bet the spool time would be amazing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic »</TD></TR><TR><TD CLASS="quote">If you can afford the gt35r go with that one... It is a bad *** turbo. I use to run the t3/t67 and it's a really good turbo aswell, but once you go ball bearing you won't go back.
we now have a ballbearing t3/to4R (t67)
for a street car with a 400whp goal, i would recommend looking into the gt3040R.
the GT3040R uses the gt30 turbine wheel mated to the 61mmGT35R compressor wheel.
the smaller turbine wheel will allow for much better reponse.
hth
hth
Re: (adSPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adSPEED »</TD></TR><TR><TD CLASS="quote">either will reach your power goal.... 35r is the **** though </TD></TR></TABLE>
yes it is
yes it is
For a 400whp goal I think they are both too big , you should consider smaller turbos.
Here are some threads about the T3/T67 vs GT35R .
https://honda-tech.com/zerothread?id=1124670
https://honda-tech.com/zerothread?id=1046654
The conclusion after reading these threads are this . If you want to build a top end motor that could rev 9000+ rpms I could go with the T3/T67 , If you are building a setup to enjoy on the street and race in the weekends I could go with the GT35R since the powerband starts at lower revs.
Good Luck
Good Luck
Mr. Badwrench
i am an exception to that rule.
i had a t04b ball bearing, and went with a t3t67 h.o. but either turbo will get you to your goal.
Modified by boostedcivicsir at 8:41 PM 10/17/2005
100% stock SR20 with stock cams, just our stage 3 kit (t3/t67) and intake mani change.
if you have any questions feel free to ask. we have a lot of sr20 experience.
Modified by Full-Race Geoff at 11:58 AM 10/18/2005
Re: (D@nnY)
i have GT30R and GT35R for sale if interested
from garrett specs
GT30R will support 520 hp. GT35R will support 620hp. this is probably HP from the crank not the wheels
from garrett specs
Re: (zeroz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeroz »</TD></TR><TR><TD CLASS="quote">i have GT30R and GT35R for sale if interested
from garrett specs
GT30R will support 520 hp. GT35R will support 620hp. this is probably HP from the crank not the wheels</TD></TR></TABLE>
they are rated by the compressors and its not a tthe wheels but those numbers arent accurate..i did 654 on a t3 35r
from garrett specs
Re: (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 »</TD></TR><TR><TD CLASS="quote">Just get a GT42R.</TD></TR></TABLE>
