Is the TurboXS Boost Controller.....
Old Oct 20, 2005 | 07:48 AM
APEXI Si's Avatar
Default Is the TurboXS Boost Controller.....
Hello quick question that I could not find I a search. Is the standard turboXS boost controller a Ball and spring design or is it something different. Also if you have any experience with it... How did it work for ya.
Old Oct 20, 2005 | 07:49 AM
notoriousB's Avatar
Default Re: Is the TurboXS Boost Controller..... (crx616)
it's a bleed valve, it is not ball & spring
Old Oct 20, 2005 | 07:52 AM
APEXI Si's Avatar
Default Re: Is the TurboXS Boost Controller..... (notoriousB)
How do they differ in performance... I ball and spring better?
Old Oct 20, 2005 | 08:02 AM
APEXI Si's Avatar
bump
Old Oct 20, 2005 | 08:08 AM
Soccerking3000's Avatar
edit i have the high performance one which has both while the standard is a bleed valve
Old Oct 20, 2005 | 08:10 AM
APEXI Si's Avatar
Default Re: Is the TurboXS Boost Controller..... (Soccerking3000)
Can anyone confirm this...
Old Oct 20, 2005 | 08:11 AM
go to their site
http://www.turboxs.com/shop_pr...ory=1
Old Oct 20, 2005 | 08:15 AM
APEXI Si's Avatar
The standard one says that it is a bleeder valve... but is there any diffrence in performance
Old Oct 20, 2005 | 08:18 AM
supposedly helps with spool time, i noticed around 400-500rpm faster spool with mine...
Old Oct 20, 2005 | 08:24 AM
APEXI Si's Avatar
With the TurboXS standard one or the TurboXS High Peformance one.
Old Oct 20, 2005 | 08:28 AM
EJ1 wilcox's Avatar
The standard is a bleeder valve and the high performance is a combination ball and spring and bleeder valve.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">supposedly helps with spool time, i noticed around 400-500rpm faster spool with mine...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx616 &raquo;</TD></TR><TR><TD CLASS="quote">With the TurboXS standard one or the TurboXS High Peformance one. </TD></TR></TABLE>
Most likely the high performance one. The ball and spring hold it closed until a certain pressure is reached and then the bleeder valve vents off excess pressure in the line so higher boost is reached before the wastegate opens up.
I had a standard bleeder valve turboxs MBC and I couldn't get it to work correctly. Even when it was all the way closed it would boost up to like 14psi or more before I let off the gas. I had a 7psi spring and was trying to get 10psi. I ended up selling it because it wouldn't work for me.
If I were you, I would at least go with the high performance MBC. But you never know, I could have had a defect because I know lots of other people who haven't had any problems with their standard MBC.
Good luck.
i have the high performance one, never had a problem and it holds boost pretty well, i personally dont like electronic boost controllers, too much to go wrong
Old Oct 20, 2005 | 08:31 AM
Default Re: Is the TurboXS Boost Controller..... (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">Most likely the high performance one. The ball and spring hold it closed until a certain pressure is reached and then the bleeder valve vents off excess pressure in the line so higher boost is reached before the wastegate opens up.
Good luck. </TD></TR></TABLE>
not to sound like an *** or anything but did you have the vacuum lines hooked up correctly?
Old Oct 20, 2005 | 08:43 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">not to sound like an *** or anything but did you have the vacuum lines hooked up correctly? </TD></TR></TABLE>
Yup.
I tried different diameters of lines, different lenghts, different configurations (off the compressor housing, then off the intake mani)...
I tried everything. LoL. I had it hooked up correctly. The source hooked to the side port and the bottom running to the wastgate side port. (I also tried using both the side and top ports with a T)
I was so frustrated after trying to many different configurations I just gave up
Old Oct 20, 2005 | 10:30 AM
pbomers's Avatar
I've only used the High Performance one, but had good luck adjusting the it without to much trouble.
The High Performance is a combination ball and spring /bleeder system. The Standard one is just a bleeder style system.
Old Oct 20, 2005 | 02:08 PM
DRAGLS's Avatar
Default Re: Is the TurboXS Boost Controller..... (pbomers)
I run the standard mbc on the supra it holds 22psi with no problems.
RICE POLICE SIP
Sep 10, 2006 10:57 AM
97grnrs
Jun 11, 2006 04:40 PM
*Boostwerks*
Apr 3, 2005 05:55 PM
Pat
Feb 27, 2003 10:04 AM
MikeExt
Dec 15, 2002 10:29 AM
