ts the proper way to place a egt probe?
hello everybody.
i was wondering how you guys put your egt prob's on your mani's.
somone told me that ususly pepole drill a hole in the mani and tap it to the correct size and thats it.
isnt it better to drill a hole and weld a bung?
thanks
thanks
Mr. Badwrench
Re: ts the proper way to place a egt probe? (RACEPAK)
if there is enough material, you can drill and tap. on our log manifolds we have done that. if you are using a thinwall tubular manifold, yes the best way is to weld in a bung.
Re: ts the proper way to place a egt probe? (boostedcivicsir)
Drilled and tapped my drag mani, about 1 - 1.5 inchs from the head, useuaully in the 3rd runner. Im an idiot and drilled and tapped it in the 2nd runner, but oh well make sure you take your time.
