Manley Rods
I just purchased manley rods and they weight only 380 grams per rod. These rods will be going in high hp turbo motor. To me they seem like na rods.
Are these rods safe in turbo motor?
Depending on the rod, All motor manleys should be close to 500g whereas the turbos are about 560. The 380 weight you are referring to is just the weight of the big end only.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">Depending on the rod, All motor manleys should be close to 500g whereas the turbos are about 560. The 380 weight you are referring to is just the weight of the big end only.</TD></TR></TABLE>
Well how would the all motor rods do with boost since they are lighter?
In the case of Manleys, they seem to have the same strength whether all motor or turbo. The extra weight is just for the thin area in the center of the rod. Turbo rods just slightly thicker in that area.
Manley AM weigh 495g
Pauter 520g
Manley TT 560g
Pauter 520g
Manley TT 560g
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">In the case of Manleys, they seem to have the same strength whether all motor or turbo. The extra weight is just for the thin area in the center of the rod. Turbo rods just slightly thicker in that area.
Pauter 520g
Manley TT 560g</TD></TR></TABLE>
Thanks for info earl
I didnt want to put these in my motor and worry about them
Then these are 498g
Pauter 520g
Then these are 498g
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote">How do these compare to eagle in price and stregnth?</TD></TR></TABLE>
They don't.....
They don't.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote">Stronger and more expensive</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote"> Stronger and more expensive?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 »</TD></TR><TR><TD CLASS="quote">They are stronger and more expensive. In fact, I can't think of a better rod in my opinion.</TD></TR></TABLE>
pauter
pauter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6junkie »</TD></TR><TR><TD CLASS="quote">pauter</TD></TR></TABLE>
Says who? More money doesn't equal better.....
thats why someone should buy my b16a...it has these rods!!!! buy it someone!!!
When i talked to Sean at ERL the other day he told me that they are switching from crower rodsto manley, he said they seem to be better than other brands.
you can always take a professionals opinion to heart.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 »</TD></TR><TR><TD CLASS="quote">Says who? More money doesn't equal better.....</TD></TR></TABLE>In Pauters case it does
i am going to buy manley rods,they make a great rod for the price.
And earl I am going to buy a set for you i had to use the money i had saved but almost got it saved back up, will pm you
silverskateEF9
31
Oct 6, 2007 07:13 PM
