+SRP pistons
Old Oct 5, 2002 | 04:08 PM
Cyber ITR's Avatar
Default +SRP pistons
i just wondering if SRP pistons can handle like 18psi boost + 60hp NOS SHOT
consider if the engine is build and tune properly
thanks
Old Oct 5, 2002 | 04:24 PM
TurboInteg95's Avatar
Default Re: +SRP pistons (VTEC_SiR)
I've seen 28 psi and 450 hp on SRP pistons.
Old Oct 5, 2002 | 09:03 PM
D-Man's Avatar
id say yes but once you throw NOS into it,itll be like a ticking time bomb,its real hard on the motor especially if your using a single fogger set-up,if anything use the 4 nozzle directport wet set up,personally,id forget about the NOS,just turn up the boost.
Old Oct 6, 2002 | 02:22 AM
Cyber ITR's Avatar
Default Re: +SRP pistons (D-Man)
so u reckon i better save a lil bit more $$$ get JE
and if i still wanna use NOS , i shud get the direct port wet system ??? is that what ur trying to say ??
thanks
Old Oct 6, 2002 | 05:40 AM
tk's Avatar
tk
If you lean out you could have titainium pistons and they will melt
The thing you should save $$ for is safty devices and tuning ,fuel supply,....etc
We used SRP in crazy setups and no bads yet,JE is a step up from SRP when extreme conditions are experienced (All out racing and no street use "trailer queen")
But if you want to spend the extra $ then go for the JE.
Old Oct 6, 2002 | 10:29 AM
Cyber ITR's Avatar
Default Re: +SRP pistons (tk)
guess ill save a lil bit more $$$
the think that makes me wanna use NOS , is becoz i dont wanna use bigger turbo
i love the way my t28 responses :D
but wat the heck
Old Oct 13, 2002 | 07:01 PM
Cyber ITR's Avatar
ttt
final question , so if i dont run NOS , and ill just run 20psi max ( with T3/T4 )
daily 12psi
so SRP should be alrite ? im aiming 250kw@wheels
( built engine , tuned properly )
[Modified by VTEC_SiR, 5:01 AM 10/14/2002]
integrawow
Jun 26, 2007 05:20 AM
Dr.Honda
Apr 19, 2007 12:29 AM
tomlinson619
May 27, 2006 10:08 PM
spencerv
Aug 28, 2002 08:39 PM
boosted3g
Nov 7, 2001 01:49 PM
