zc zdyne tune
zc zdyne tune
I should be receiving my zdyne any time now. Is there anyone that could give me a tune that will work with a zc t25 and 450 cc injectors(intercooler not installed yet). I am not planning on running more than 10lbs boost. any help would be appreciated thanks.
Re: zc zdyne tune (linx)
Here's a pretty good one:
http://www.geocities.com/civic_fi/zdyne/zdyne.html
The one by Ricky Crow, says turbo zc. I believe it was originally designed with a t-25 in mind. I know a few people have been running it for the past year or so with good results.
Good luck,
Ryan P.
Good luck,
Ryan P.
Re: zc zdyne tune (SJP0tato)
Yo Pete, I just downloaded those files to my laptop. Let me know when you get your ecu so I can download the program in your car.
Re: zc zdyne tune (MIKES)
What fuel/setup etc are you guys going to be running?
My ZC map is running over 10 DEGREES of advance added over the Zdyne base maps in certain places. A freind and i had immense trouble when using Zdynes base maps, and maps based on their base maps. Zdyne's maps appear to be a work of fiction, and have many errors in them.
I'm running 98octane and 6psi of boost making 173 flywheel bhp and 158lbs-ft at 4900rpm with a greddy 92-95 civic kit on my ZC (and there is plenty more to come without upping the boost) When i was using the Zdyne map as a base i was only gaining 5hp - yeah that's FIVE horsepower and my power curve was diabolical, and all i had was a slight low-end torque increase- pathetic.
Zdyne's ZC base maps bear utterly no resemblance to a stock ZC map. I dumped a stock JDM ZC map from my ECU (i stay in the UK and my car is a genuine JDM CRX Si) and it was vastly different. If anyone wants it just ask as i don't want anyone to go through the trouble my freind an i had.
The map i'm running at the moment is a stock ZC extrapolated for boost and with the fuelling recurved for my larger injectors.
Cheers,
Mark.
REDBARON
12-23-2001 12:46 AM
