Throttle position sensor....adjusting
Old Oct 4, 2002 | 04:31 AM
deacs's Avatar
Default Throttle position sensor....adjusting
I have read that some off the low throttle jerkiness associated with The AFC hack and 450cc's can be overcome by slightly modifying the throttle position sensor?
Is this true and if so how do i do it???
I have a 1993 civic with a D16Z6.
thanks
paul
Old Oct 4, 2002 | 05:30 AM
Sleeper's Avatar
Default Re: Throttle position sensor....adjusting (deacs)
I don't know what affect the it will have on the hack. Remove the tb and observe the 2 screws holding the tps on. If its USDM, the tops are sheared off when installed. Slot them with a dremel, loosen and rotate the tps to achieve desired voltage, tighten. Removal isn't necessary, but its easier to slot them.
Old Oct 4, 2002 | 07:22 AM
deacs's Avatar
Default Re: Throttle position sensor....adjusting (Sleeper)
Just had a look at it and it looks more like rivets??? holding the TPS on to the throttle body. Not sure though. why the hell didnt they use normal screws/bolts!!
deacs
Old Oct 4, 2002 | 07:25 AM
Dutchie's Avatar
deacs
Ya I know. Those **** bastards. Funny because Hondas are generally pretty home mechanic friendly, then they go and do something like that.
Old Oct 4, 2002 | 10:19 AM
deacs's Avatar
Default Re: Throttle position sensor....adjusting (Dutchie)
yeah right pain, spose the throttle body/housing will have to come off???
deacs
Old Oct 4, 2002 | 01:46 PM
boostinb18's Avatar
no all you have to do is slot the rivets and they thread out!!!! its very easy.
Old Oct 7, 2002 | 10:30 AM
98R-1144's Avatar
Default Re: Throttle position sensor....adjusting (boostinb18)
how do you slot the other rivet w/o taking off the TB? i can only see 1 rivet on the top side... can't see the rivet on the bottom
DerekHollister
Mar 25, 2016 04:42 PM
turboef90
Mar 23, 2009 10:07 AM
GSRcivicGSR
Dec 20, 2004 04:29 AM
thrty8street
14
Oct 24, 2004 03:30 PM
SIcivic10
Sep 29, 2002 05:33 PM
