will i notice a hp difference from a drag to inline pro?
Old Oct 4, 2002 | 08:53 AM
93B17A's Avatar
Default will i notice a hp difference from a drag to inline pro?
just as it says cause i'm sick of the boost spiking going on with this drag 2 manifold. will there be a difference in hp? also will i have any fitting problems swapping the two manifolds? TIA
Old Oct 4, 2002 | 08:56 AM
MatT3T4's Avatar
Default Re: will i notice a hp difference from a drag to inline pro? (93B17A)
I would imagine the inlinepro manifold has better flow capabilities than the drag 2...???
Old Oct 4, 2002 | 09:05 AM
jinxproof99's Avatar
New User
Default Re: will i notice a hp difference from a drag to inline pro? (MatT3T4)
you will see zero boost spike caused by an inlinepro manifold. the drag manifold blows.
Old Oct 5, 2002 | 06:34 AM
93B17A's Avatar
Default Re: will i notice a hp difference from a drag to inline pro? (jinxproof99)
yeah tell me about it.......at 10 psi its fine, but at 14 psi i can't get it to be stable,and i'm tired of it
Old Oct 5, 2002 | 09:53 AM
Ri5e's Avatar
Are you running a 3 Inch exhaust system? What wastegate are you using?
Old Oct 5, 2002 | 12:37 PM
New User
Default Re: will i notice a hp difference from a drag to inline pro? (4 Stroke)
run 3" with no cat and a tial or hks wastegate for best results.
Old Oct 6, 2002 | 09:48 PM
hatchy's Avatar
How is this a manifold problem? Are you running a shitty wg?
Old Oct 6, 2002 | 09:51 PM
The_Head's Avatar
Default Re: will i notice a hp difference from a drag to inline pro? (hatchy)
It's probably a deltagate. They are notorious for boost creep, I've seen it myself.
Old Oct 7, 2002 | 08:21 AM
93B17A's Avatar
Default Re: will i notice a hp difference from a drag to inline pro? (xThexHeadx)
i'm currently running a tanabe racing medallion exhaust, and the downpipe extended to get rid of the cat. i plan to do a full 3 inch exhaust as soon as i find out wether or not i'm getting a T60-1. and yes i am unfortuate to be running a delta wastegate, cause i don't have the hood clearance to fit the tial (another reason why i wanna change the manifold)
delsinner13
Aug 10, 2006 07:27 AM
b00sted4dr
Nov 15, 2004 09:25 AM
11psiTurboSI
May 6, 2004 08:21 AM
Bictorious
Feb 26, 2004 10:51 AM
TurBoTeG
Oct 31, 2001 11:55 PM
