... resistor box (not crx)... can i use it?
... i finally found a resistor box (actually, i found 2)... one from a 90 civic dx and one from a 93 prelude... i was wondering if i can use these to run dsm injector or not... anyone know?... i read earlier on h-t that these have different resistances compared to the resistor boxes found on crx's... well if anyone knows if i can run either or both of these resistor boxes, lemme know... thanks...
Re: ... resistor box (speedworks)
so it should ALL work then. i was at the junkyard today and can NOT find any of these resistor boxes. can somebody enlighten me? i found several older accords and 3 CRX's. where are these resistor boxes? .....on a great note, i found a set of DSM 450cc injectors for $23.75!
Re: ... resistor box (newgsrdriver)
he he he... i got very lucky. an older eclipse GST has been sittin in the middle of the yard untouched. i saw 2 guys jumped in and started pulling out the turbo. i asked if they needed the injectors. they said no. it's cheap on this junkyard. those guys pulled out the td05, BOV, exhaust manifold, SMIC, both cams (gear), and was charged less than $200.
