need help fast... where does this little do-hickey go?!
ok... nitrous wet kit install... everything has gone smooth until my friend and i are to tap the fuel line. The nx nitrous kit instructions are for a god damn carburated car so that didn't help worth a damn.
Which line do i tap? the one going into the fuel pressure regulator... like in this pic, labeled "fuel in" highlighted in blue
or is it this big ****** thing labeled "fuel line" (black hose w/ red writing)
by the way, this is on a 2001 accord lx 4cyl
Re: need help fast... where does this little do-hickey go?! (tegasaurus)
I am allmost 100% sure that the black fuel line is the one you need to tap, call them and ask if it needs to be before the regulator or after.
Rob
Rob
Re: need help fast... where does this little do-hickey go?! (ED9Hybrid)
Got it installed... byt the way, this is on my friends 2001 accord LX. started saturday at about 6 p.m.... putzed around, hookin some wires up at random, lookin at the pictures (or lack there off) blah blah blahc till bout 12:00, That's when my friend ands and i actaully started to work... Got everything finally finished at 4 or 4:30 a.m. then went to go test the solenoids and listen for the infamous "clicks." To no avail. Checked the wiring, checked it again, checked the battery... did that for bout 2 hours. then my friend and i decided to make our own wiring diagram. It worked. like a charm... finally finished bout 6:30. Put in the 35 shot and holy ****... ****** haaauls! we're waiting the arrival of 2 step colder NGK plugs and a crane ignition (i think it's crane, maybe my friend god msd?) then we're bustin ou the 75 shot
Thanks for your help guys. The imput made the long night slightly shorter.
doing a zex wet kit, and im wondering where the fuel line is that i need to tap already seacrhed ...
TABIAS
11-29-2003 12:29 PM
