will these pistons work?
Old Oct 5, 2002 | 07:27 AM
gsr squirrel's Avatar
New User
Default will these pistons work?
i know a person selling a set of endyn roller wave (wiseco) pistons for a b16a. they are 84mm and yeild a 9.5:1 compression. will these pistons work in a b18c resleeved to 84mm or b20 block that is already 84mm? the head is from a 98 jdm type-r. so does anyone know if i can use these?
Old Oct 5, 2002 | 09:48 AM
New User
Default Re: will these pistons work? (gsr squirrel)
Old Oct 5, 2002 | 10:19 AM
Ri5e's Avatar
Yeah, they will work. But your compression Ratio will be higher then 9.5:1 with a GSR head.
Old Oct 5, 2002 | 10:25 AM
New User
Default Re: will these pistons work? (4 Stroke)
b18c5/b16a head + b20b block
b18c5/b16a head + b18c1 84mm block
does anyone know about where my cr would be?
Old Oct 5, 2002 | 12:20 PM
New User
once more
Old Oct 5, 2002 | 12:46 PM
Mr. Softee's Avatar
Gotta find out more about the piston dome displacement CC's
Old Oct 5, 2002 | 01:00 PM
Boostfed's Avatar
New User
You definately need to to CC the motor, my Endyn RW psitons were supposed to be 9.7:1 but in reality were 8.9:1. B series pistons are interchangeble.SUpposedly Endyn and some other companies don't have a B16A piston but give you a GSR piston instead. Hearsay so.
Old Oct 5, 2002 | 07:01 PM
New User
Default Re: will these pistons work? (94goldjungsr)
it says compression ht is 1.180
and bore is 3.308.
need any more info.
mzaner
Aug 21, 2006 03:42 PM
celph.
Dec 7, 2003 09:05 PM
VTECVillain
Jan 10, 2003 01:57 AM
hybridhatch90
Nov 11, 2002 05:34 PM
