? about AFC hack settings..
Old Oct 3, 2002 | 11:58 AM
TurbothisLS's Avatar
Default ? about AFC hack settings..
do i set the AFC to -40% all across, before i start the car for teh first time? Do I do it after?
Old Oct 3, 2002 | 12:03 PM
CzanSOHC's Avatar
Default Re: ? about AFC hack settings.. (TurbothisLS)
before you start the car, set to -40%, then set high and low throttle at 98% and 99%. I would set higher RPM's to -37%-38%...
Old Oct 3, 2002 | 12:04 PM
shadowdawn's Avatar
Default Re: ? about AFC hack settings.. (CzanSOHC)
What he said should do you fine for 7psi or 8 at most
Old Oct 3, 2002 | 12:12 PM
Default Re: ? about AFC hack settings.. (shadowdawn)
cool thanks guys/gals
it says on the dropshop website that the thr setting don't matter, i see most people using 71/72 instead of the 91/92
does it really matter?
Old Oct 3, 2002 | 12:18 PM
boostinb18's Avatar
do it doesnt really matter since the wide and narrow settings are the same....it can be 2% and 4% if you want.
Old Oct 3, 2002 | 12:19 PM
shadowdawn's Avatar
Default Re: ? about AFC hack settings.. (boostinb18)
It doesn't matter, because your hi and lo settings are the same...
Old Oct 3, 2002 | 12:21 PM
hey dawn, what do you mean by double mesh filter? did you jsut get two wire mesh peices and cut them and clamp them on to the turbo compressor side?
Old Oct 3, 2002 | 12:26 PM
shadowdawn's Avatar
Exactly that
Old Jun 4, 2004 | 11:51 AM
MooreBoost's Avatar
Are his high and low settings the same because he doesn't have VTEC? I will be running a DOHC ZC with the hack, so my high/low settings dont matter either, right?
Old Jun 4, 2004 | 01:52 PM
swlabhot's Avatar
Default Re: ? about AFC hack settings.. (tegunderpressure)
You high and low throttle % only matters if your fuel settings for narrow is different to wide. In the normal hack settings the high/wide and low/narrow fuel trims are set to be the same hence the throttle % does not matter.
Old Jun 4, 2004 | 03:20 PM
MooreBoost's Avatar
Default Re: ? about AFC hack settings.. (swlabhot)
Why doesn't so the throttle % matter? Im really having trouble grasping the hack idea.
Does the high/low throttle setting mean which map the ECU runs? Like one for 25% throttle (low) and another for 80% throttle (high)? Please explain.
So I can leave my high/low settings anywhere?
Old Jun 4, 2004 | 05:19 PM
Haberdasher's Avatar
Let's say that for all RPM segments, both high and low throttle, you set them to -40%. Now, at any RPM and any throttle percentage it's going to use a -40% correction. It doesn't matter what the hi/low throttle percentage switch point is because no matter where the throttle is it uses the same settings, -40%.
Old Jun 4, 2004 | 06:25 PM
MooreBoost's Avatar
Default Re: ? about AFC hack settings.. (Haberdasher)
Will that not make it stupid rich at part throttle then?
Dubs13
Suspension & Brakes
Jun 19, 2008 08:43 PM
BoostedD15B7
Nov 12, 2003 06:18 PM
civictypenos
Oct 6, 2003 08:07 AM
99lspwr
Aug 28, 2003 07:54 PM
civictypenos
Aug 25, 2003 04:37 AM
