N20+SC
Old Oct 2, 2002 | 03:31 PM
NCSTIdriver's Avatar
Default N20+SC
Anyone ever ran nitrous with a JRSC? How did it perform???
Old Oct 2, 2002 | 04:10 PM
CRVRX's Avatar
Default Re: N20+SC (NCH22driver)
Is the N20 a new motor? , Is it a 2.5L ?
Old Oct 2, 2002 | 04:55 PM
Default Re: N20+SC (CRVRX)
I mean Nitrous with a supercharged engine sorry about that.
Old Oct 3, 2002 | 08:36 AM
fire7882's Avatar
I know a guy that did and ran a 12.2 on completly stock d16z6. His motor didn't last very long.
Old Oct 3, 2002 | 08:39 AM
DS1's Avatar
DS1
Boost is already hard enough fo H22 they tend to fail... so i wouldnt do nitrous as well if your block is stock
Old Oct 3, 2002 | 02:02 PM
CRVRX's Avatar
Default Re: N20+SC (DS1)
Supercharged motor usually run real good with a little NOS. On a heathly motor a 25 shot will usually give you 30-40WHP , as is cools so well plus the nos makes HP.
Keep it to 25 shot and it will be fine.
Old Oct 3, 2002 | 03:05 PM
redintegra's Avatar
Won't you need to upgrade injectors with this? Stock injectors with SC = 100psi fuel pressure as it is. So to use nitrouse without suicide, larger injectors is a must I think. I could be wrong
Old Oct 3, 2002 | 05:37 PM
Default Re: N20+SC (redintegra)
I have Hondata and some 550cc's wating to be installed. I am not planning on adding N20 that is just too much money I could barely afford this SC i'm still in highschool. Once i get tuned i will be fast enough. Then maybe some supension, quafie, motor mounts, and some new rims.
Old Oct 3, 2002 | 08:00 PM
speedy108's Avatar
The Hondata S200 has a new Nitrous Control feature coming out within a month and that is what I plan to do with my JRSC GSR running 9psi. I will be using a 25 HP shot dry kit.
Old Oct 3, 2002 | 08:11 PM
dustin's Avatar
Preludes have really weak pistons.... be careful.... JRSC likes to break those pistons.
If you are still in high school, you'll probably want to leave the prelude N/A.
Old Oct 3, 2002 | 10:06 PM
hondaswaper's Avatar
Default Re: N20+SC (dustin)
i saw a 92 hatch drag car with a JRSC on like 20psi and a directport NOS kit........it ran high 10s with DR. Charles tuning it.......
Old Oct 4, 2002 | 11:50 PM
FMXer's Avatar
Default Re: N20+SC (94hondahybrid)
I have been wanting to add a 25 shot to my car for a while now.
But when i see pics of what a D16's rods look like i worry that they will snap like tooth picks, am i wrong to assume this?
The s200 will have a N2O feature? what like seprate map?
Old Oct 6, 2002 | 02:13 PM
MooreBoost's Avatar
Default Re: N20+SC (FMXer)
The guy at my shop says no to run anything lower than 40-45. Other wise it just feels like you downshifted.
gmoore
Old Oct 8, 2002 | 10:37 PM
FMXer's Avatar
Default Re: N20+SC (gmoore379)
gmoore
I dont understand this...
bump
caus i want some N2O in my ride
Old Oct 8, 2002 | 10:47 PM
PrecisionH23a's Avatar
https://honda-tech.com/zerothread?id=299791
MARVNVRAM
Apr 18, 2007 12:41 PM
superman336
Feb 1, 2007 08:19 AM
95accordh22a
Mar 2, 2005 05:50 AM
blu2ksi
Dec 9, 2003 08:45 AM
toEknEEg
Dec 22, 2002 01:01 AM
