Need Help with installation of S-AFC!!!! help please, installing now!!!!!
Old Oct 6, 2002 | 09:11 AM
T25 civic's Avatar
Default Need Help with installation of S-AFC!!!! help please, installing now!!!!!
I went through the instruction manual and I think I've figured out the wiring, but I want to double check before I start:
The IG power wire conencts to pin number 11 on connector A (yellow/black wire IGP1)
The Ground wire connects to pin number 9 on connector A (Brown/Black wire LG1)
The RPM Signal wire connects to pin number 20 on connector A (Yellow/Green wire ICM)
The Throttle Signal wire connects to pin number 1 on connector D (Red/Black wire TPS)
The Pressure signal wire connects to pin number 3 on connector D (Red/Green wire MAP)
The blue wire mod, what wire would I connect that to? Would it be the same wire that I connected my A/F gauge to, or is it a different wire on the ECU?
Can anyone see any wire that I'm wrong on? I'm a little confused on the RPM signal wire cause the wiring diagram show that wire is called the IGN input signal, anybody have some input? Also, on one of the manuals it said something about the brown wire for the ground needs to be connected closer to the ecu, and another manual said it should be closer and the black one connected 1 CM away! Does it really matter or should I do it just because? Any help is greatly appreciated.
Nick
[Modified by T25 civic, 6:14 PM 10/6/2002]
Old Oct 6, 2002 | 10:02 AM
T25 civic's Avatar
Default Re: Need Help with installation of S-AFC!!!! help please, installing now!!!!! (T25 civic)
anyone?
Nick
Old Oct 6, 2002 | 02:11 PM
T25 civic's Avatar
nevermind, I got it figured out, thanks for the help
90_EX_Civic
Mar 21, 2009 07:59 PM
aznryd3r
Nov 24, 2006 10:05 AM
hotimportcrx
Nov 1, 2005 07:19 AM
14bcoupe
Welding / Fabrication
12
Apr 19, 2005 11:20 AM
