Hondata question
Old Oct 3, 2002 | 02:19 PM
minivan81's Avatar
Default Hondata question
Hey guys,
I'm planning to purchase a Hondata s200 w/boost soon for my up coming turbo project (93 hatch/stock b16a)
Currently I'm running a P08 JDM 92-95 Civic D15z ECU .. chipped Mugen program, DOHC specs.
Question..
Will I encounter any problems hooking up the s200 with this ECU setup?
I'm thinking it should be fine, but I just wanted to make sure first.
Thanks guys,
-Van
Old Oct 3, 2002 | 02:57 PM
GruvyTune's Avatar
New User
Default Re: Hondata question (minivan81)
there are no problems except that you will need to replace your mugen chipped ecu with a hondata modified one. if you are chipped already they all you have to do is burn a hondata chip to go in the socket. you will need tuning of course
Old Oct 3, 2002 | 03:11 PM
ekb18c's Avatar
Default Re: Hondata question (GruvyTune)
Yup, Let's hope that the people who chipped your computer used a socket instead of just solder the chip right onto the board. It makes it harder if there isnt a socket there, then you will have to desolder the chip out and then resolder the socket back in.
Old Oct 3, 2002 | 03:50 PM
minivan81's Avatar
Default Re: Hondata question (ekb18c)
Yeah, its socketed, so I won't have to resolder.
So I'll need a modified Hondata chip eh? About how much more does it cost to get along with a s200 unit?
-Van
Old Oct 3, 2002 | 04:01 PM
GruvyTune's Avatar
New User
just need someone to get you started with a basemap but i would get it to a wideband tuner like myself asap.
Old Oct 3, 2002 | 04:32 PM
ekb18c's Avatar
Your also going have to solder in one more piece to the board, to interface with the blue box.
Old Oct 3, 2002 | 04:39 PM
boostinb18's Avatar
i have a quick question about the hondata..... once you have the basemap chip in there do you ever have to replace it??? or when you chang ethe settings on the hondata do you have to put in a new chip?? these are probably stupid questions but im just cconfused! thanks guys!
Old Oct 3, 2002 | 05:34 PM
ekb18c's Avatar
Default Re: Hondata question (boostinb18)
The chip is where the info is stored. So basically each time you need to change somethign in your ignition or fuel table, you will have to take that chip out, put it on the pocket programmer and burn it, after you have mad changes to it. Only the tuner should be burning the chips or making any major changes to the system.
Base maps are just that, base. If you get a base map, you will have to get it tuned later on. a base map is just a map that starts your car.
edit- Please check http://www.hondata.com for more info.
[Modified by ekb18c, 2:34 AM 10/4/2002]
Old Oct 3, 2002 | 05:42 PM
boostinb18's Avatar
oooooohhhh ok......... so i cant tune it myself???
Old Oct 3, 2002 | 05:51 PM
ekb18c's Avatar
You could tune if you have either a 4b(if you have the stage 2/3) or if you have a full s200 system(for s200 models only). Also you will need a wide band o2 with meter and you would have to purchase the pocket programer with the emulator.
Oh yah and also a basic knowledge of how a motor works etc. If you don't know too much about a/f and how the motor works then I wouldn't tune it myself, if I were you.
Old Oct 4, 2002 | 01:53 PM
boostinb18's Avatar
yah i am pretty good wiht tuning my vafc hack but its no where near to as deep as the hondata.......how much would it be with the pocket emulator and all that with a s200 system???
Old Oct 4, 2002 | 02:49 PM
ekb18c's Avatar
vafc and hondata tuning are way different. I would recommend that you get it tuned by a tuner. Check http://www.hondata.com for prices.
Old Oct 4, 2002 | 07:38 PM
Hondata's Avatar
A base map is just that. A stock or mildly modified stock map. the Hondata system has many base maps and many tunes to start with. Some of them are very good.
A properly tuned chip with a (good) turbo setup for example can get you 30 plus mpg and 400HP.
Nicks95GSR
Dec 3, 2008 04:48 PM
Chrislow
Mar 20, 2005 06:02 PM
aziz93
Aug 16, 2004 08:29 AM
StinkyTofu
Dec 29, 2002 11:51 PM
Jared
Apr 17, 2002 04:29 AM
