Need Help
Old Oct 3, 2002 | 06:24 AM
hybrid901's Avatar
Default Need Help
Just finished installing a drag 3 kit on a 00 gsr last night. We had to cut the downpipe down to about 5" because it wouldn't clear the oil return fitting. My problem is the car doesn't want to idle and when I take it out of gear it will stall. But if I just rest my foot on the gas pedal it will idle fine. I'm thinking its a fuel issue but could it be from not having any back pressure from the downpipe only being so short.
Old Oct 3, 2002 | 08:32 AM
hybrid901's Avatar
Default Re: Need Help (hybrid901)
anyone?
Thanks
Old Oct 3, 2002 | 08:39 AM
DSF's Avatar
DSF
No. You do have a turbo before the downpipe, correct? So you do have backpressure, but that's beside the point as it wouldn't effect anything anyway.
Old Oct 3, 2002 | 08:44 AM
FredoSP's Avatar
What does your fuel sys consist of?
Old Oct 3, 2002 | 09:26 AM
hybrid901's Avatar
Default Re: Need Help (FredoSP)
Everything is the stock drag setup. Fmu, inline pump. If either of these is hooked up wrong or bad would it cause this? Anything I can try?
Old Oct 3, 2002 | 02:22 PM
hybrid901's Avatar
and suggestions? How bad is it to drive with no downpipe?
Old Oct 3, 2002 | 02:37 PM
Arturbo's Avatar
Better than steak
25 Year Member
Make sure the leads on the fuel pump are on right. Also see if the fuel pump is going tin the right direction.
art
Old Oct 3, 2002 | 04:45 PM
hybrid901's Avatar
Default Re: Need Help (Arturbo)
Could not having either O2 sensors hookup on a odb2 car cause this? We have swapped out the map sensor with another 1 and nothing, also unhooked the vaccume lines to teh bov, fmu, and boost guage and nothing. Please any suggestions this car is driving me crazy.
TOP*SECRET
Apr 21, 2005 08:37 PM
ITRpwrdEG
Jul 2, 2004 02:35 PM
89civic1.8T
Aug 31, 2002 12:35 PM
zerodrag29
Mar 1, 2002 09:51 PM
