Need help with my internal wastegate
Ok I just bought this turbo
the internal wasted gate is set around 10-12 ish, I want to run about 8. I dont want to buy an external wastegate and I can't change the length of the arm becuase there arent any threads, so my question is should I buy this?
http://cgi.ebay.com/ebaymotors...09095
any sugestions would be great thanks
Re: Need help with my internal wastegate (92lxsedan)
It would be easy to cut out a section and weld in a piece of threaded rod and use a coupling/locknut to make your own adjustable rod.
Total cost would be around $5.
- Slater
- Slater
Re: Need help with my internal wastegate (Slater)
not for 75 dollars you shouldnt.
There are home made ways to lengthen your WG actuator arm, do a little searching and I am sure you will find something.
