fuel pressure regulator and fuel rail what is better for up to 20psi (already searched)
I am looking between the aem package or the str rail with a b&m command flo regulator. Has anyone used these and what would be better for a street/strip setup. I am using a walbro 255 in-tank fuel pump. Any help will be appreciated. Thanks,
-swoosh
-swoosh
Re: fuel pressure regulator and fuel rail what is better for up to 20psi (swoosh)
You will be fine with the stock rail and regulator. Boost is not the limiting factor. HP is. There are plenty of 500+ cars running stock rails, lines and regulators. But if you must, either will be fine.
