225/50/15 tires work on boosted 93 dx hatch?
I was wondering if anyone had ran 225/50/15 on a eg hatch with eibach pro springs. I think the spring drop is 1.2 all the way around it looks like it will work but the ride height is a litte taller like the 205/50/15 ride height is 23.07" and the 225/50/15 ride heght is like 23.87". The car is a street car with a built b18c1 with t3/to4e turbo will be running about 300whp. I would like to get as much tire to the ground as I can. Does anyone have pics of the 225/50/15 on a eg I have searched and find anyting on the subject. Any input will be helpfull THANKS>>>>>
Re: 225/50/15 tires work on boosted 93 dx hatch? (2.0lhatch)
i ran 225/50/15's on an ek with the pro-kit & a b-series. they rubbed on top and on the inside at full steering lock. these were hoosier R3S03's and were wider than most 225's.
i now run 215/50/15 for the street with the integra sportlines. these BARELY rub at full lock and don't rub on top unless i hit the bumpstops. the tires are kumho ecsta 711's and are $43/ea last time i checked!
material can be removed at the top of the fender where it meets the body to keep from rubbing on the top of the tire. with that done i think 225/50's on the street would be no problem. this is all for an EK hatch though, so i dont know if it will help. however the 215's are more likely to work and are definately good for the money.
hth!
hth!
Re: 225/50/15 tires work on boosted 93 dx hatch? (Wide Open Throttle)
The only problem with the 215/50/15 is tire selection is very small. 205/50/15 is out of the question not wide enuff.
Come on eg guys where are you at pics please really need help!!!!
Yeah they should work. Some guy in Drag Racing used them. BFG's he posted the lowest street tire time on them. CHeck there!
Re: 225/50/15 tires work on boosted 93 dx hatch? (T4sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4sol »</TD></TR><TR><TD CLASS="quote">
WOT,
what size rim were you using to run the 225's?</TD></TR></TABLE>
15x7's. i think 225's are the most you could fit on a 7" wheel. 235's might work, but who makes them?
sorry for the late reply(spring break).
WOT,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wide Open Throttle »</TD></TR><TR><TD CLASS="quote">
sorry for the late reply(spring break).</TD></TR></TABLE>
BFG comp TA drag radials have some 235 60 15's
Re: 225/50/15 tires work on boosted 93 dx hatch? (boostedb20vtec)
i hope it doesn't rain or snow where you live if you plan on running that wide of a tire size on the streets. last year i ran 205/50/15's during the spring and summer and when it rained i had problems with hydroplanning.
anyway, the largest 15" tire size i was able to fit on to my eg hatch were 215/50/15's which only rubbed when doing a full turn and when i hit bumpstops and ditches.
Re: 225/50/15 tires work on boosted 93 dx hatch? (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang »</TD></TR><TR><TD CLASS="quote">i hope it doesn't rain or snow where you live if you plan on running that wide of a tire size on the streets. last year i ran 205/50/15's during the spring and summer and when it rained i had problems with hydroplanning.
anyway, the largest 15" tire size i was able to fit on to my eg hatch were 215/50/15's which only rubbed when doing a full turn and when i hit bumpstops and ditches.</TD></TR></TABLE>
i have no problems with hydroplaning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslowh23 »</TD></TR><TR><TD CLASS="quote">what offset wheel whould you run?</TD></TR></TABLE>
+41mm
+41mm
Daniel san
21
04-11-2005 10:10 PM
60-1teg
03-03-2004 08:45 PM
GoLowDrew
01-30-2002 08:31 PM
