B16's out there with Turbo I need ur opinions
Ok I recently had a JDM GSR swap out and I wanted to try something different, so anyone out there with b16 swaps with turbo, I need to know how much are u putting down to the wheels, and what all have u beatin on the track and street, cause if I get good respondes I'll get a b16, if not back to the B18c1 for me.
Re: B16's out there with Turbo I need ur opinions (Austinbionic316)
If you do a search on the board, you'll see that b16s are making just as much power as the b18s are. The torque is a tiny bit less, but other then that their roughly similar. I believe its boostfed on here who has an 84mm b16 with 28-29 psi making 600+ whp. So its really up to you.
Re: B16's out there with Turbo I need ur opinions (SpoolnG2)
eh 600whp for a daily driven car is too much for me, i'll just stay with 390 to 400whp...thanks I know I can get 250whp at 8psi and probably about 390 anywhere from 12-15psi
I've got a JDM B16, with parts from the companies listed in my profile. I dont race though, and have a sleeper so I never get reved on or anything - making about 240hp
Sorry not very helpful
Re: B16's out there with Turbo I need ur opinions (TeamCracka)
hey man its good, dont worry bout it, all I know is I know on the JDM GSR swap out I can get 270whp with the way i build my motor at a low psi, but I was hopping to get the same kinda results with the b16, cause I know like the JDM b16 is like 170hp and about 150 wheel hp so I mean its good..
Re: B16's out there with Turbo I need ur opinions (Sohc Driver)
Yeah I think I will go back to the GSR swap even tho I wont be able to get it cheap like I did before, but ya know...but I can always get the b16swap and run that for a min then get the b18c motor, and ecu and I'll be good, cause I would have the mounts, and axles...
The Axles should work on that b18 right? the axles that came with my b16 swap out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austinbionic316 »</TD></TR><TR><TD CLASS="quote">
The Axles should work on that b18 right? the axles that came with my b16 swap out?</TD></TR></TABLE>
Yes sir...also..I guess you could always go for the b16 swap..and swap out with a GSR block later on...thats if your up for it...b16s are very capable motors, but if i had my choice to start out..i would go for the GSR
Banned
get a b16... and boost it... you wont be disapointed im sure.
Modified by Irishweird00 at 2:33 PM 3/4/2004
Re: B16's out there with Turbo I need ur opinions (Irishweird00)
no man..if u read my sig I dont have it anymore due to a wreck...thats why I was askin what I asked
xwhitchx
29
03-10-2010 08:28 AM
